I am trying to transmit data from one Microcontroller (ATMega8A default clock frequency) to another Microcontroller (ATMega16 16MHz-crystal).
I have setup ATMega16 as master with
DDRB |= (1 << DDB7) | (1 << DDB5); //Set MOSI, SCK as Output
SPCR |= (1 << SPE) | (1 << MSTR) | (1<<SPIE) | (1 << SPR0);//Enable SPI, Set as Master
I have a receive function
unsigned char ReceiveData(unsigned char Data)
SPDR = Data;
while(!(SPSR & (1<<SPIF) ));
return(SPDR);
The SS'
pin of ATMega8A (slave) is connected to PB3
and in the main loop I have
for(;;)
PORTB &= ~(1<<PB3); //clear SS' of slave
Data = ReceiveData(0x05); //sending dummy 0x08 to slave;
if(Data == 0x08)
//TOGGLE(SOME_PORT,SOMEPINWITHLED); toggle #defined
_delay_ms(200);
PORTB |= (1<<PB3);
In the slave device I have
int main() // slave main module
DDRB |= (1<<DDB4); //MISO as OUTPUT
SPCR |= (1<<SPE); //Enable SPI
DDRB |= (1<<DDB0);
char Data = 2, SendValue = 8;
for(;;)
TOGGLE(PORTB,PB0); // #define'd TOGGLE(A,B) A ^= (1<<B);
Data = SendData(SendValue); // exact same as ReceiveData() on master.
return 0;
The led doesn't toggle at the master module but does at the slave module. Could you suggest me what have I done wrong here. May be the master and slave are not synchronized.
- Should I check `while(!(SPSR & (1 <<SPIF) ));` on the slave or `SPDR = Data; return (SPDR);` is sufficient on the slave.
- How does the master know when the slave is sending data? So, when should maser check `while(!(SPSR & (1 <<SPIF) ));`?
P.S: In the future I plan to use multiple slaves and a single master.
Edit : I corrected from DDRB |= (1 << DDB3) | (1 << DDB5);
