I'm designing a circuit that uses an optocoupler to isolate a relatively noisy H bridge from the USB circuitry also present on the board. Clearly in this case I will have two grounds - what is the norm for dealing with these in terms of ground planes?
My initial thought is to have 2 ground planes, 1 on the USB side and 1 on the H Bridge side of the board (isolated from each other), but could this cause problems with capacitance if one of the grounds were to rise above the other?
