We know that to convert unsigned to signed (precisely, I want to convert a pure binary into CA2 number) we must negate the unsigned number adding, then, + 1. In VHDL I can implement an inverter and an adder that manages the carry in. I have two numbers of 32 bits. Is there another way to implement the sum + 1 using anything cheaper? Is there a solution to manage the carry in using only logic gates?
  • \$\begingroup\$ No, that's for taking the negative of a number. Changing the signedness doesn't involve changing the bit pattern. \$\endgroup\$ – Ignacio Vazquez-Abrams Sep 7 '15 at 21:35
  • \$\begingroup\$ Yeah I know that the pattern is the same, but I need of negative number, I need to see it like a CA2 number \$\endgroup\$ – Develobeer Sep 7 '15 at 21:37
  • \$\begingroup\$ CA2, CA-2 or CA II may refer to : Carbonic anhydrase II, a human gene California's 2nd congressional district Hummel CA-2, an ultralight aircraft California State Route 2 Ca II, a singly-ionized calcium that produces the H and K lines in the spectrum of many stars \$\endgroup\$ – Bruce Abbott Sep 8 '15 at 0:46
  • \$\begingroup\$ In other words, what (precisely) is a "CA2 number"? It is not a common technical idiom. \$\endgroup\$ – Dave Tweed Sep 8 '15 at 0:59
    \$\begingroup\$ CA2 : In French it would be "Complément à 2"="Two's complement". \$\endgroup\$ – TEMLIB Sep 8 '15 at 1:11
It really isn't worth worrying too much about this detail. Adding 1 to a number is such a common idiom in HDL that synthesis tools have highly-evolved methods for dealing wtih it. Also, most modern FPGAs have dedicated, hard-wired fast carry logic that does not consume logic cells, and that synthesis tools know how to take advantage of.
  • \$\begingroup\$ Thank you for answer. So, do u suggest to implement it in behavioral way and leave everything to synthesizer? \$\endgroup\$ – Develobeer Sep 8 '15 at 11:15
If it's unsigned, it is by definition positive, therefore it's 2's complement equivalent is also positive, therefore the bit pattern representation is the same.
The one difficulty arises if its MSB is already set : then it is an unsigned too large to represent as a signed number of the same size. So the completely general answer is to sign-extend it into a 2's complement number at least 1 bit wider :
my_signed <= '0' & my_unsigned;
