I have a motorcycle headlamp that I am lighting outside of a motorcycle. It's a stage prop, I have the front end of a motorcycle built as my microphone stand. The bulb has hard set 3 terminals, two leads and 1 common out. I am wanting to put a blinker on one of the lights (high beam) and have a switch just for on and off on the other light (low beam).
I am wondering if I am running into a problem where the common terminal on the light comes out and I have to split the cable to run to the two negative terminals. Will the current split and distribute amongst the two? Will this work ok? I have the two power supplies to provide enough amps to run both of the lights. By the way, this is DC Current. Thanks so much for your help.
    \$\begingroup\$ Can one supply provide enough current for both connections? \$\endgroup\$ – Ignacio Vazquez-Abrams Sep 7 '15 at 23:27
    \$\begingroup\$ When doing the math the circuit would pull more amps than just one of the supplies would provide. Thinking it would overtax it if it did even work. \$\endgroup\$ – willb41 Sep 7 '15 at 23:33
Your setup will work fine. KCL states that each supply will take back from the negative only as much current as they put out on the positive.
  • \$\begingroup\$ @willb41: Please mark the answer as accepted then. \$\endgroup\$ – Fizz Sep 8 '15 at 4:34
