after finishing some designs, it is time to manufacture and assemble them.
For making these designs I have to create all padstacks, footprints, etc from scratch, so I took PCB Editor examples as guide for doing mine. Now, when I send the gerbers (etch layers, soldermask, silkscreen, drill) to our manufacturing house, they requested me the pastemask ones. Although they can generate them from gerbers, they are enquiring me to generate the pastemask gerbers with our own requirements. So, I need a little help to get the proper guidelines to avoid any possible error.
Then, I wonder if you can provide some guidelines about how to define and create the proper pastemask layers.
From PCB Editor examples, most of passive components have no pastemask defined (SMT and THR), and from IC pads the relation between pads size and solder paste are 1:1 in most cases.
I have in mind next possible requirements:
  1. THR components: 1:1
  2. SMT components with padstack larger than 1mm: 1:1
  3. SMT components with padstack shorter than 1mm: 1:0.9
  4. IC perimeter pads: 1:1
  5. QFN perimeter pads: 1:0.9
  6. QFN thermpad: <1:0.7
  7. BGA pads: 1:0.9
  8. Any other pads: suggestions accepted
Are these requirements right?
And finally,
  1. Which is the best option, provide pastemask layer to manufacturers? Or should I let him create them?
  2. In the case, I have to create the pastemask layers, which are the best guidelines to follow them?
Kind Regards.
  • \$\begingroup\$ Maybe I am daft, but why a pastemask opening for THR components?? (Assuming that means THRoughole) \$\endgroup\$ Sep 8, 2015 at 15:22
  • \$\begingroup\$ @WoutervanOoijen, yes THR means THRough hole. I just want to ensure to follow the best guidelines. I have preferred to ask the absurd to not make mistakes on assembly. \$\endgroup\$
    – Yolco
    Sep 8, 2015 at 15:35
  • \$\begingroup\$ How will you assemble the TH components? I assume either by hand, or using reflow? In both cases solder paste on your PCB doesn't make sense to me. \$\endgroup\$ Sep 8, 2015 at 15:36
  • \$\begingroup\$ You are right. Question has no sense. But please, next time, try to help not only ask about a failure o unkownledge. \$\endgroup\$
    – Yolco
    Sep 8, 2015 at 15:44
  • \$\begingroup\$ You overestimate my knowledge. It just seemed strange to me, so I asked. Spehro has added this detail to his question. \$\endgroup\$ Sep 8, 2015 at 15:50
I believe that the IPC recommendation is to make the stencil apertures the same size as the pads.
Altium, for example, allows you to set the paste expansion via rules or individually, but the default is 0.0mm.
You don't generally want solder paste on through-hole pads.
Usually paste with stencil apertures the same as the pads is also recommended for BGA, but it's said to be possible to just use flux.
  • \$\begingroup\$ Thanks @spehro pefhany. I am wondering about due to at some datasheets you can find as recommendation not to use more than 0.7% of thermpad size, 0.9% of pad size, etc. \$\endgroup\$
    – Yolco
    Sep 8, 2015 at 15:42
  • \$\begingroup\$ Thermal pads are different. Follow the recommendations of the manufacturers. \$\endgroup\$ Sep 8, 2015 at 15:43
