10
I am designing a PCB for use with an Arduino mega and I am wondering if there is a good rule for how much space I should leave between the edge of the PCB and various items like:
  • traces (ground, 5v supply, 9v supply, and 5v digital signals)
  • surface mounts
  • small through holes (capacitors)
  • mounting holes (for screws)
  • large through holes (power supplies)
I currently have 0.1" around everything except of a through hole for a DC jack, which comes .05" from the edge. Can I remove some of this space and not hurt my design?
    \$\begingroup\$ Are you working with a specific fab house, or wondering if there's a generic "maximum minimum" that is safe no matter which Chinese fab is making your design? \$\endgroup\$ Sep 10, 2015 at 4:17
  • \$\begingroup\$ I'm using expresspcb.com \$\endgroup\$
    – Hoytman
    Sep 10, 2015 at 15:59
  • 10
    \$\begingroup\$ Because this is my first PCB. \$\endgroup\$
    – Hoytman
    Sep 11, 2015 at 18:59
  • \$\begingroup\$ isn't expresspcb.com/express-pcb-manufacturing-service answering your questions? Minimal space is stated... \$\endgroup\$
    – schnedan
    Sep 7, 2020 at 9:06
10
surface mounts
Collectively, all these are covered by the minimum copper to board edge clearance parameter.
The value is driven by the precision with which the PCB fab can register the board before it's routed. Typical value is 0.020". Narrower clearance is possible, but the fab may charge extra for additional precision. So, check with the fab, the clearance should be on their "capabilities" page (like this one).
Distance of mounting holes for screws is driven by a mechanical considerations. My rule of thumb is to keep the distance between the edge of the hole and edge of the board at least as big as the diameter of the hole. But this can vary greatly depending on how much vibration your assembly will see, and how heavy are the components on the board.
[hint: Separate question.]
    \$\begingroup\$ Worth noting that for the Wun Hung Lo board house, 0.030" is probably safer. \$\endgroup\$
    – Matt Young
    Sep 10, 2015 at 4:23
  • \$\begingroup\$ The minimum clearances and other parameters are usually specified in a DRC (Design Rule Check) file, and used to verify the layout meets these rules before Gerbers are generated. \$\endgroup\$
    – tcrosley
    Sep 10, 2015 at 5:02
    \$\begingroup\$ The PCB layout software usually has some default value for each kind of clearance. The actual value for the clearance, though, should come from the PCB fab side of things. \$\endgroup\$ Sep 10, 2015 at 5:06
  • \$\begingroup\$ I generally plan for 25mil, though for high-quality board houses I have gone down to 15mil. That's pushing my limits though \$\endgroup\$
    – DerStrom8
    Sep 10, 2015 at 16:25
  • \$\begingroup\$ that means 0.762mm, 0.03 inches or 30mil \$\endgroup\$
    – sairfan
    Jan 31, 2021 at 17:55
In your case (and this is true for all but the cheapest Wun Hung Lo fabs, from what I can tell), you are safe with a 20mil clearance, as per the ExpressPCB design rules doc.
The other answers here did a good job of addressing the issue of board edge clearance from the point of view of PCB fabrication but there is also the issue of board assembly.
One contract manufacturer recommends at least 0.15" between the edge of the board and any surface mount component pads. This is to allow proper clamping of the solder paste stencil.
Also consideration should be given to clearance for the fixtures which hold the PCB during automated assembly.
And there is also the issue of how the PCB is separated from the panel. If the edge is routed, then there is no problem. But if the PCB is v-scored or tab routed you should consider the mechanical stress placed on the components near the board edge when the pcb is separated from the panel. Ceramic capacitors are particularly susceptible to cracking.
