I have an electric gate opener that takes a 15-18v AC input. Around 100m from the gate I have a 240v outdoor circuit that I'd like to use to power the gate and some garden lighting.
I can't find any specifications on exactly what current the gate will draw, however the readily available transformer for it is rated at 16v, 3.75A. It's only supposed to be located approx 20m from the gate though and I'm concerned that even with expensive 6mm cable, the voltage drop will be too great using this transformer. Overseas they use an 18v transformer and locate it up to 100m from the gate, however I'm struggling to find a suitable one in Australia. There are, however, plenty of outdoor rated (IP67) 24v AC transformers.
So I'm wondering is there any relatively cheap and reliable way to take this 24V AC which, when the gate and lights are operating, might drop to as low as 20V AC at the end of the cable run and get a voltage that stays in the 15-18V AC range from it to power the gate?
