I am trying to analyze a circuit where AOZ1014 buck converter is used to generate 7.5V and negative voltage(-5V) is generated with following arrangement.
aoz1014
As shown above Lx pin of AOZ1014 ( left sided pin of inductor L2 )is assigned to 7905 regulator with C33,D16 and D18 arrangement. Here, as per my consideration, D18 is for suppressing +ve peak to ground since we need -ve input to 7905 IC.
What is the purpose of D16, R57 and C33 here? How changing C33 will change my output voltage?
I used same concept with TP5430 Buck regulator as shown.
tps
But I am getting random results in my case here. Sometimes it is regulating as per my requirement but randomly misbehaves with loading 7.5V to 1.5V and -5V to -2v. Am I correct in assigning C33 pin to in between of C31 and L2? Can someone guide me to make it work.
Thanks in advance.
D18 and D16 will rectify the AC voltage at pin 8 of U14. It is similar to a voltage doubler rectifier.
This can work usefully however it relies upon U14 continually producing a square wave at that pin. It may not do so if the load on the main output (7.5V) is at a low current level.
Many switching regulators go into various low power nodes when the load is reduced - pulse skipping, PFM (pulse frequency Modulation) or similar. These will result in the signal to D18 not being continuous and could give the symptoms you see.
Make sure you have a load on the main output - use a resistor to simulate the final product load if necessary.
  • \$\begingroup\$ Thanks, Kevin.. But, are u saying load at 7.5V node..how to choose value..even I connect 500E load, it's loading sometimes. Why C33 used and how it's value is calculated? \$\endgroup\$ Commented Sep 11, 2015 at 17:36
