I have these smartphone headphones and I am trying to replace the 3.5mm headphone jack. I purchased a replacement jack and then stripped back the wires on my headphones to see this.
I was not expecting the red and white twisted cable (on left of photo) but I imagine that's the cable for the button on the headphone cable.
I have my soldering iron ready, but what am I soldering?
closed as off-topic by PeterJ, Null, Ricardo, Daniel Grillo, Nick Alexeev Sep 14 '15 at 18:59
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the repair of consumer electronics, appliances, or other devices must involve specific troubleshooting steps and demonstrate a good understanding of the underlying design of the device being repaired. See also: Is asking on how to fix a faulty circuit on topic?" – PeterJ, Null, Ricardo, Daniel Grillo, Nick Alexeev
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ A guess and you could verify if you have some basic tools: red right, green left, copper headphone return, twisted pair mic plus and minus \$\endgroup\$ – Some Hardware Guy Sep 12 '15 at 0:26
Use a multimeter to verify which wires connect to the Left and Right headphone connections.
Tin the end of each wire - leave them long for now to make things easier for you.
Set your multimeter to the "Diode Test" range or the Ohms "X1" range if that's what your meter has.
Put the headphones on your head and touch the meter leads to any two wires. If you hear a click out of one side, one of those 2 wires is the Left side and the other side is Common.
Now touch the meter leads to one of those first wires and another wire. If you hear a click out of the other side, you now know which wires are for the headphones.
If you hear a click out of BOTH sides, you have identified the Left and Right wires. It's now a simple matter to find the common wire.
As mentioned in the comments, the twisted pair is likely the mic if this is a headset with a mic mounted to it. You are going to have to try connecting it both ways to see what the polarity is. That said: a good first guess is that Red is (+) and Grn is (-).
