I am just wondering if there is any simple circuit to measure the frequency of a signal near 100MHz. A FM demodulator IC may do it but I need it to be simple and without ICs (aka, only containing discrete R, L, C, diodes, transistors and such). There is very loose requirement about the response time -- as long as the output can settle in less a second when frequency shifts by 20%.
  • \$\begingroup\$ If you are wanting to measure the frequency, in what form are you hoping to have the measurement reading supplied to you - I don't see that any of R, L or C have a built-in display. \$\endgroup\$
    Sep 13, 2015 at 8:37
  • \$\begingroup\$ Something easier to measure, such as slower voltage and such. \$\endgroup\$
    – shva
    Sep 13, 2015 at 15:46
A PLL is the best way, especially since your signal is in the middle of the FM broadcast band. But if you want the circuit to be passive, you can use a slope detector. Make a narrowband filter at 100 MHz. Then use a diode to make an envelope follower (also called an AM detector circuit, like a crystal radio.) The signal strength will be greater when the signal is closer to 100 MHz.
Theremins did something like this for the volume control. The oscillator is shifted in frequency by the hand, and the output frequency is passed through a filter, and then diode rectified to create the control voltage.
You don't mention how much signal level or range of variation you have to work with.
