I have always believed that it was ok to replace a capacitor with a slightly higher voltage rated one. eg 16v with 25v.Going higher than this would risk the capacitance value being out at the working voltage. However I just read the following quote from this pdf
Electrolytic capacitors are non-ferroelectric with a very low dielectric constant. Their capacitance is derived from a very high surface area and nanometer thick dielectric layers. Their capacitance is not a function of applied voltage.‐Design Solutions For DC Bias In Multilayer Ceramic Capacitors (August 2010 Electronic Engineering Times)
So does this rule not apply to aluminum electrolytics? Eg will I have no issues replacing an electrolytic 25v 100uf with a 50v 100uf assuming both are low esr, similar footprint and good quailty?
