I am using Pic16f877 microcontroller for my project. I am trying to declare a char Array as
char dataPkt[256] = {0};
While compiling, i received an error
error: (1250) could not find space (256 bytes) for variable dataPkt
Can anyone guide me how to resolve this error ??
    \$\begingroup\$ That device only has 368 bytes of RAM and you are trying to reserve 256 of them. I suspect you have other variable declarations too? You need to live within your budget ;-) \$\endgroup\$ Sep 14 '15 at 9:08
  • \$\begingroup\$ @RogerRowland, thanks for your comments. I tried with 100. And I m not using enough variables too.Than too the error remains the same. Can you guide me alternate way to overcome the issue ? \$\endgroup\$
    – skg
    Sep 14 '15 at 11:03
    \$\begingroup\$ If you look at page 13 of the datasheet, you'll see that there are multiple banks of memory. For your array, you need contiguous bytes in a single bank. The largest bank is 96 bytes. The others are 80 bytes. There's little chance of finding the space you need in a single bank. \$\endgroup\$ Sep 14 '15 at 11:08
  • \$\begingroup\$ RTFM! - - - - - \$\endgroup\$ Sep 14 '15 at 11:08
  • \$\begingroup\$ @Roger: There's actually as many as 112 bytes available consecutively (110h-17Fh, inclusive)... who knows if the compiler is smart enough to treat it as a single block when needed.... and of course the multimapped region is usually too valuable to waste like that. \$\endgroup\$
    – Ben Voigt
    Sep 14 '15 at 16:23
6
There is no substitute for understanding the machine at the low level. Whether using a compiler or not, you have to actually READ THE DATASHEET.
As Figure 2-3 on page 13 clearly shows, there is no way to get 256 contiguous bytes of RAM.
Other observations:
  1. MPLABX is the IDE, so is useless in specifying what compiler or assembler you are using.
  2. Allocating a buffer for a whole packet sounds like big-processor thinking on little processors. There is no OS with canned drivers that is going to read/write whole packets from/to some communication interface. Ultimately, code is going to handle each byte separately anyway. Buffering a packet of bytes, then reading and handling them out of the packet individually anyway makes little sense.
  • \$\begingroup\$ thanks for your reply. What if I use pointer instead of array ?? There is no compile error. Will it also have bytes limitation ??? \$\endgroup\$
    – skg
    Sep 14 '15 at 11:19
    \$\begingroup\$ @skg: A array and a pointer are two completely different things. You need to learn some basics of programming and what a machine does under the hood before continuing. \$\endgroup\$ Sep 14 '15 at 11:21
  • \$\begingroup\$ @skg, I think it's best for you to look into the "Understanding Small Microcontrollers" book (available online for free). \$\endgroup\$ Sep 14 '15 at 14:52
  • \$\begingroup\$ "big-processor thinking" This is exactly the issue. +1 \$\endgroup\$
    – Ben Voigt
    Sep 14 '15 at 16:24
