I am designing a 12-5 V Buck converter on a pcb (as part of a larger design) with a LM2596S-5.0 and using one of the recommended diodes, a 50WQ03.
On the datasheet, both pins 1 & 3 are connected to the anode, and 2 & 4 connected to the cathode, however it looks like 2 isn't able to be connected to the pcb because it is too short and not lowered to the same level as the rest of the pins, as well as not being included on the recommended pcb footprint.
I was wondering if it is in any way advantageous to use both pin 1 & 3 (I am thinking more copper area for heat dissipation), or just one of them, and also what the purpose of a stub pin (not sure if this is the correct name) like pin 2 is?
I was wondering if it is in any way advantageous to use both pin 1 & 3 (I am thinking more copper area for heat dissipation) or just one of them
To properly carry the power (Voltage * Current) for the diode, both pins should be used, with appropriately sized traces. But the anode pins are not the primary heat dissipation in a DPAK package. The Tab is. Look at the pad layout near the end of the datasheet. The entire back of the DPAK needs to be soldered on (reflow soldering of course). That's the primary heat sink away from the body, as well as it's body dissipation to air.
The TO-252/DPAK comes in a variety of pin types, some with a stub pin in the middle, and some without (the pin is fully extended). In most cases it's always tied to the tab. While I can't be sure of what Vishey engineers thought in the design, it's likely due to two reasons. The manufacturing process for the stub version was cheaper likely due to scale, and as a way to force the use of the larger tab pin. Had the pin been fully extended, someone might decide that they will only solder the pins and not the tab, resulting in untimely heat related damage.
You are right, connecting both A-pins can increase thermal dissipation depending strongly on your pad design and base material.
The shortened pin 2 is just a result of economic production measures at the manufacturer. A typical lead frame for through hole packages is used and excess parts of the lead frame are removed after the package is molded.
