I am interfacing PIC32 MCU with 24 inputs and UART. When any inputs comes, this data is transferred to PC via uart. I am using multiple if condition like
if(input1==high)
  putsUART("input 1 ON\n");
if(input2==high)
  putsUART("input 2 ON\n");
What this if condition is doing is whenever an input comes, it keep on printing the data like
input 1 ON
input 1 ON
input 1 ON
and it goes on. I want it to be displayed once only. For example, if I applied input1, input 1 ON should be printed once and if remove the input input 1 OFF should be displayed once. I don't know how can I run this if condition only once. Please help. Thanks.!
CODE(just for 3 inputs):
 int main()
  TRISAbits.TRISA6 = 1;
  TRISAbits.TRISA7 = 1;
  TRISGbits.TRISG13 = 1;
  while(1)
   if(PORTAbits.RA6 == 0)         //INPUT 1
   putsUART2("Input: 1 ON\n");
   Delayms(1000);
  if(PORTAbits.RA7 == 0)          //INPUT 2
   putsUART2("Input: 2 ON\n");
   Delayms(1000);
  if(PORTAbits.RG13 == 0)          //INPUT 3
   putsUART2("Input: 3 ON\n");
   Delayms(1000);
    \$\begingroup\$ You need to remember the state of each input, and only output to the UART if it changes. \$\endgroup\$ – Roger Rowland Sep 15 '15 at 6:55
  • \$\begingroup\$ I have edited my question. Can you tell me how can I remember the state for input? \$\endgroup\$ – Aircraft Sep 15 '15 at 7:12
  • \$\begingroup\$ I don't know exactly why your approach is what it is, but why wouldn't you pack your 24 inputs into 3 bytes, and when any one of them changes, or just periodically, sent all three bytes to the computer? \$\endgroup\$ – Scott Seidman Sep 15 '15 at 13:13
  • \$\begingroup\$ @ScottSeidman looks great. Can you give an example.! \$\endgroup\$ – Aircraft Sep 16 '15 at 4:18
Something like this, just for one input so you get the idea :
// NB - put these lines outside your loop
uint8_t uLastRA6State = 0;                // last known state of RA6
uint8_t uLastRA7State = 0;                // last known state of RA7
// ... etc.
// use one variable for each input, or if memory is tight, you could
// alternatively use one byte per 8 pins, but this more "wasteful"
// version is easier to understand the principle
while (1)
    // NB - put this code inside your loop
    if (PORTAbits.RA6 != uLastRA6State)
        // save current state
        uLastRA6State = uLastRA6State ? 0 : 1;
        // output change
        if (uLastRA6State)
        else
            putsUART2("Input: 1 OFF\n");
    // ... do the same for other inputs, e.g.
    if (PORTAbits.RA7 != uLastRA7State)
        // ... similar to above, for RA7
  • \$\begingroup\$ thanks for giving me this idea. But its still displaying continuous values \$\endgroup\$ – Aircraft Sep 15 '15 at 7:40
  • \$\begingroup\$ @CZAbhinav Well the code above should never output consecutive ON's or OFF's. Are you saying it is doing so? Are your inputs changing too fast for your UART buffer? \$\endgroup\$ – Roger Rowland Sep 15 '15 at 8:15
  • \$\begingroup\$ yes it is doing so. and I just found out that I have not applied any input but still its showing input 1 ON \$\endgroup\$ – Aircraft Sep 15 '15 at 8:27
    \$\begingroup\$ You might need a pull-up resistors on your pins to keep the inputs to a stable/default level. If an input isn't connected to anything, it can randomly be 0 or 1.. \$\endgroup\$ – m.Alin Sep 15 '15 at 8:55
  • \$\begingroup\$ I am working on PIC32 starter kit, so I think I dont need any pull ups. Inputs are already stable.! \$\endgroup\$ – Aircraft Sep 15 '15 at 8:58
