I like to analyze bluetooth low energy advertising packages on an Arduino Uno. This tasks poses me problem because the BLE modules I have found only work in device mode (Adafruit, RedBearLab, and other nRF51822 and nRF8001 based) and can't collect data. Does anyone know about such projects or have experiences with this?
  • \$\begingroup\$ NRF51 devices do support central role. Just use the correct softdevice (S120/S130). \$\endgroup\$
    – Turbo J
    Sep 15, 2015 at 20:06
  • \$\begingroup\$ Are there tutorials for reprogramming? I have a JLink and a nRF51 but I'm unsure about the wiring. \$\endgroup\$
    – Sider
    Sep 15, 2015 at 20:16
Adafruit has the Bluefruit Sniffer requires a host PC instead of an arduino UNO (http://www.adafruit.com/product/2269) it basically has a nrf51822 module which talks to the PC over a UART using the FTDI usb to Serial converter chip. I suspect that you could probably get a similar nrf51822 module and flash the sniffer firmware( found here: https://github.com/adafruit/Adafruit_BluefruitLE_Firmware/tree/master/sniffer/1.0.1)use the Jlink to flash the firmware onto the BLE module and use that to communicate with the arduino UNO over a uart connection. Hope that helps, Good luck!
you can try using one of these modules maybe:
http://www.seeedstudio.com/depot/MDBT40P%C2%A0%C2%A0nRF51822%C2%A0based%C2%A0BLE%C2%A0module-p-2503.html
https://www.adafruit.com/products/2479
