I am trying to do uart program in pic. I want to display characters send by controller to pc. But i am not able to do this. following is my code
#include<pic.h>
__CONFIG(0x3f72);
#define FOSC 10000 //10Mhz==>10000Khz
#define BAUD_RATE 9.6 //9600 Baudrate
#define BAUD_VAL ((char)(FOSC/ (16 * BAUD_RATE )) – 1)
void main()
unsigned char ReceiveChar;
TRISC=0xc0; //RC7,RC6 set to usart mode(INPUT)
TXSTA=0x24; //Transmit Enable
SPBRG=BAUD_VAL; //9600 baud at 10Mhz
RCSTA=0x90; //Usart Enable, Continus receive enable
TXREG='0';
while(1)
if (RCIF==1) //char received? Send 'A' back to Terminal
ReceiveChar=RCREG;
if(TXIF==1)
TXREG=ReceiveChar;
#define BAUD_VAL
has a potential bug: you should never usechar
type for arithmetic, because it has implementation-defined signedness. \$\endgroup\$
