In the reference schematic of an Ethernet transceiver, I noticed that the chassis ground is connected to system GND by 1nF/2kV Capacktor(C24). What is the purpose of doing this?
The connector(J1B121ZCCD) contains transformer.
Because someone has pointed that my question is duplicate, I will explain. My question is that why the 2kV capacitor is there, and not why it is 2kV.
    \$\begingroup\$ Duplicate electronics.stackexchange.com/questions/66119/… \$\endgroup\$
    – efox29
    Sep 18, 2015 at 5:00
    \$\begingroup\$ @efox29: that questions asks why it is 2kV, not why it is there at all \$\endgroup\$
    – PlasmaHH
    Sep 18, 2015 at 9:36
  • \$\begingroup\$ @efox29 NO. It is not a duplicate question. I looked at your link and it does not answer my question in terms of why the 2kV capacitor is there(not why it should be 2kV) at all. \$\endgroup\$
    – Steve
    Sep 21, 2015 at 1:40
  • \$\begingroup\$ The purpose of doing this is to provide a return path (to the chassis) for a common mode RF noise "leaking" across the (embedded/exposed) transformer. Typically, 1 or 2 (but may be 3 and more) HV caps may be placed per each port (jack). The cap(s) must be placed as close as possible to the transformer/transformer-enabled jack. \$\endgroup\$
    – asndre
    Oct 9, 2015 at 18:35
The capacitor provides a low impedance path for RF currents between the cable screen and ground.
To be effective in reducing radiation from the cable, the screen needs to be connected to the chassis earth of each device.
But as thick Ethernet provides galvanic isolation between devices, to a kV level, it wouldn't do to simply connect the two grounds together.
A 1 nF capacitor has an impedance of 1.6 ohms at 100 MHz, this is low enough to provide a good RF ground. At 60 Hz it is >2 MOhm, so it won't pass any significant current at power frequencies.
(Ethernet uses a NRZ encoding and in theory doesn't have any low frequency components, see here for some detail).
Of course this is only useful if the cable is screened. If the cable is unscreened, the capacitor will only help screening the connector chassis with its magnetics, much less important. Also, I'm surprised not to see a bleeder resistor. Anything which is isolated by a capacitor can be charged up to many kV by static in the atmosphere, in ideal conditions. When this reaches 2 or 3 kV, it breaks through and destroys the capacitor. A 1 MOhm bleeder would prevent this. Perhaps the jack already has a spark gap inside, for contact ESD.
    \$\begingroup\$ I think you generally mislead the OP, because: \$\endgroup\$
    – asndre
    Oct 9, 2015 at 18:17
    \$\begingroup\$ 1) The screen = coax related term?, shield in twisted pairs case, if any, shell be connected at least at one side of the connection \$\endgroup\$
    – asndre
    \$\begingroup\$ 2) Thick Ethernet = 10BASE5 operates over a coax cable. As from the schematics, OP is interested in 10BASE-T / 100BASE-TX both working over a twisted pair based cable. \$\endgroup\$
    – asndre
    \$\begingroup\$ 3) Ethernet uses NRZ only at MII. At MDI, 10BASE-T uses Manchester, 100BASE-TX uses MLT-3, 10BASE5 uses Manchester too, even 100BASE-FX uses NRZI. \$\endgroup\$
    – asndre
    \$\begingroup\$ 4) There is no surprise in the absence of a breeding resistor. How do you think a 1.5kVrms 1MOhm resistor looks? A BR is placed at the point where (and if) the chassis and common gnds are connected. Generally, the BR is also used in parallel with a low-volage (50V-100V) capacitor. \$\endgroup\$
    – asndre
    Oct 9, 2015 at 18:18
There reason for the capacitor is to meet the electrical safety standard for leakage to chassis from any other signal. To validate the isolation an Hi-Pot test is performed at 1500Vac on every production units.
