I have designed a Arduino shield that is designed to be placed in the field and log data from a sensor which it then saves to an SD card. In order to log this data, I must convert 5v SPI to 3v3 of course, so I designed in a TXB0104 (datasheet) 4 bit logic level converter.
This logic level converter outputs extremely noisy signals that only make it up to ~2v, with an extreme amount of noise between 1v and 2v. This noisy-ness occurs both when the SD card is inserted and when it is not. Here is an oscilloscope capture of one of the data lines:
Oscilloscope capture
Here is a picture of the board itself (R1 is not necessary BTW):
Board picture
And a picture of the schematic:
(Sorry it's so crowded, I have the free edition of Eagle. Can't do multiple sheets.)
Board Schematic
The 3v3 regulator (datasheet) does not appear to be browning out. It is rated for 800 mA.
Another possible source of error that I think is fine is the IC (datasheet) to switch the 3v3 regulator on (it is battery powered, so trying to conserve battery life while it is off). The power switch is rated for 2A.
One mistake I made when laying out the board is that there is no 3v3 decoupling caps extremely nearby the logic level translator IC. However, C1 (0.1 uF) is on the 3v3 line and very near the 3v3 regulator output there is a 100 uF electrolytic, so I don't think that is the main issue.
The code I used in testing the SD card is as follows:
#include <SPI.h>       // For SPI communication to the SD card
#include <SD.h>        // For interfacing with the SD card
//********************* PIN DEFINES *********************************
#define V_BATT        A0      /* Battery Voltage Detection */
#define CURRENT       A1      /* Motor current measurement pin */
#define LLS_EN        A2      /* Logic level shifter enable */
#define GREEN_LED     A3      /* successful startup */
#define RED_LED       A4      /* Error */
#define XBEE_TX       0
#define XBEE_RX       1
#define ENC_2         2
#define ENC_1         3
#define CARD_DETECT   4
#define MOTOR_EN      5
#define MOTOR_DIR     6
#define MOTOR_PWM     7
#define REG_3v3_EN    8
#define REF_4096_EN   9
#define SD_CS         10
#define SD_MOSI       11
#define SD_MISO       12
#define SD_SCLK       13
void setup() {
    Serial.begin(9600);
    pinMode(GREEN_LED, OUTPUT); // GREEN LED
    pinMode(RED_LED, OUTPUT);   // RED LED
    pinMode(CARD_DETECT, INPUT);
    pinMode(REG_3v3_EN, OUTPUT);
    pinMode(REF_4096_EN, OUTPUT);
    pinMode(LLS_EN, OUTPUT);
    pinMode(SD_CS, OUTPUT);
    pinMode(SD_MOSI, OUTPUT);
    pinMode(SD_MISO, INPUT);
    pinMode(SD_SCLK, OUTPUT);
    analogReference(EXTERNAL);
    delay(100);
    digitalWrite(REG_3v3_EN, HIGH);  // Turn on SD and misc 3v3 stuff
    digitalWrite(REF_4096_EN, HIGH); // Turn on 4.096v ref
    delay(250);
    digitalWrite(LLS_EN, HIGH);      // Turn on logic level shifter
    delay(500);                      // wait for everything to settle
    if(digitalRead(CARD_DETECT) == LOW) {
        if(!SD.begin(SD_CS)) {
            // Error, could not initialize SD card. Flash Red LED
            Serial.println("ERROR: Couldn't initialize SD card.");
            while(1) {
              delay(125);
              digitalWrite(RED_LED, HIGH);
              delay(125);
              digitalWrite(RED_LED, LOW);
        else {
          Serial.println("Success");
    else {
      Serial.println("ERROR: No card inserted");
      while(1) {
        delay(500);
        delay(500);
    while(1) {
        digitalWrite(GREEN_LED, HIGH);
        delay(1000);
        digitalWrite(GREEN_LED, LOW);
        delay(1000);
Any ideas are appreciated! I'll post back with updates if I make anymore progress.
  • \$\begingroup\$ I don't see either of the bypass capacitors the TXB0104 datasheet explicitly says you're supposed to place as close to each power rail as possible. \$\endgroup\$ Commented Sep 19, 2015 at 23:20
  • \$\begingroup\$ Also, how are you measuring that? Make sure your probe ground connection is as close to the level-translator ground as possible, you could have ground voltage differences. \$\endgroup\$ Commented Sep 19, 2015 at 23:23
  • \$\begingroup\$ I admit, I should have put those caps in. I forgot. However, there's no way that was the root issue. The lines are well bypassed upstream from the IC. Also, I wasn't using a ground connection near the IC, but there's no way that would ever account for 1.2v discrepency with a low impedance ground plane and low currents. (I also measured between where I was probing and my ground connection - ~0v difference) \$\endgroup\$
    – TylerH
    Commented Sep 20, 2015 at 0:03
It appears the enable line of the TXB0104 is not configured appropriately. Please verify you have this setup as the datasheet calls out!
  • \$\begingroup\$ This appears to have been the issue. Unfortunately, even after I fixed the OE line on the chip to reference to 3v3 instead of 5v, it appears the chip is fried. It doesn't toggle high/low properly under load. \$\endgroup\$
    – TylerH
    Commented Sep 20, 2015 at 0:00
It looks reasonable.
I suggest that you write some test code to specifically set the pins on the interface to high low and tri-state to see what is happening.
It is difficult to diagnose when you have a complex sequence in progress such as initializing the SD card.
  • \$\begingroup\$ Thanks for the suggestion! This helped me debug the problem. No matter if the pin was high/low/tristated, it all produced the same noise pattern. Looks like I fried the chip due to the OE pin being pulled to 5v instead of 3v3. \$\endgroup\$
    – TylerH
    Commented Sep 19, 2015 at 23:59
