I am new to the whole Arduino thing and am having problems loading 'Processing'.
When I attempt to run the Processing program it says 'This Program requires Java Development Kit 1.5.0'. When I go the the Sun site to load this, I can't find SDK 1.5.0.
Does anyone know the exact name of the app I have to load in order to successfully run Processing? A web link to the correct app would be greatly appreciated.
  • \$\begingroup\$ What operating system do you use? Windows or Mac? \$\endgroup\$ – Toby Jaffey Mar 16 '10 at 23:05
You need the sun JDK 1.5 or above (current is 1.6) there http://java.sun.com/javase/downloads/index.jsp you may need the JRE too, I can't remember if it's included with the JDK.
If you're on linux then it's easier to use your distributions own packaging system to install.
You want "Java for your Desktop", as they call it on the Java.com homepage. The easiest way to get that is to go to Java.com's "Free Java Download" page: http://java.com/en/download/
Just accept all the defaults (but probably uncheck installing the Yahoo toolbar), and in a few minutes you'll have Java on your system.
(btw, you don't need Processing to use Arduino)
Go to http://www.java.com/getjava/ and follow the download link.
  • \$\begingroup\$ Thanks very much to chemicaloliver, todbot and Joby Taffey for your responses. Strange.....works fine on one laptop but not the other. Mystery??? Thanks to everyone. John \$\endgroup\$ – John Mar 18 '10 at 2:13
