In NXP's I2C specification and user manual Rev. 6, it states we can put series resistors on SDA and SCL lines for protection against high-voltage spikes:
And it gives a graph, to show the relation between Rs and Rp:
I wonder how NXP get this graph, if there is a closed form equation to show the relation between Rs and Rp?
  • \$\begingroup\$ SDA and SCL pin does have it's own capacitance (which limits switching speed), and Rs additionally limits charging current. I think they've calculated that figure from condition that allows to switch with needed speed (just as Rp calculates for long lines). \$\endgroup\$
    – Looongcat
    Sep 24 '15 at 5:38
8
Rp and Rs form a voltage divider. Rs must be low enough to keep the voltage on the line below VIL-VnL. They must also be small enough to sink at least IOL.
We therefore have the following:
Is - Ip >= 3mA
Vs / VDD <= 0.2
Vs + Vp = VDD
Solving for these simultaneously results in the output shown in the chart.
