I want to reset the variable v_count to 0 at the rising-edge of input port i_pulse_run. But I get the following errors:
Error: Could not Implement register on this clock edge.
Error (10821): HDL error at PWM_Gen.vhd(85): can't infer register for "CTRL:v_count[15]" because its behavior does not match any supported register model.
How else can I reset the variable to 0. I want to reset it only at the rising edge of signal i_pulse_run.
Any suggestions are welcomed. Thanks
LIBRARY IEEE;
USE IEEE.numeric_std.all;
USE IEEE.std_logic_1164.all;
CTRL : PROCESS(i_Reset, i_Clock,i_pwm_pulse_run)
variable v_PWMout        : std_logic;
variable v_intPWMvalue    : integer range 0 to 8192;
variable  v_updatePWMvalue  : std_logic;
variable v_count : integer range 0 to 65535;
begin
if i_Reset = '0' then
  -- Asynchronous reset
  o_PWM        <= '0';
  s_PWMCounter     <= 0;
  v_updatePWMvalue  := '0';
elsif rising_edge(i_Clock) then
-- Increment the PWM counter
   if s_PWMCounter < i_PWM_Freq_Div - 1 then
      s_PWMCounter   <= s_PWMCounter + 1;
   else
      s_PWMCounter   <= 0;
      if rising_edge(i_pulse_run) then
          v_count := 0; -- Error
      end if;
      if i_pwm_pulse_en = '1' AND  v_count < i_pulse_count +1 then
         v_count := v_count + 1;
      end if;
end if;
end if;
end process CTRL;
D-Flops are only sensitive to the rising edge of one clock. In your case, you don't actually want it to change on the rising edge of i_pulse_run because the rest of your circuit is clocked off i_clock; what you should do is have another register saving the value of i_pulse_run on each clock cycle, and then when the input value of i_pulse_run != saved i_pulse_run, you are on the rising edge.
    \$\begingroup\$ I think you mean when i_pulse_run = '1' and i_pulse_run_saved = '0', not just when they differ. \$\endgroup\$ – scary_jeff Sep 25 '15 at 14:11
You are trying to design a register that updates on the simultaneous rising edges of i_Clock and i_pulse_run. Avoid nested edges.
What you want to do is:
begin if i_Reset = '0' then -- Asynchronous reset o_PWM <= '0'; ... elsif rising_edge(i_Clock) then ---This is what is important i_pulse_run_prev <= i_pulse_run; ---!!---------------------------- -- Increment the PWM counter if s_PWMCounter < i_PWM_Freq_Div - 1 then s_PWMCounter <= s_PWMCounter + 1; else s_PWMCounter <= 0; if rising_edge_pulse_run then v_count := 0; elsif i_pwm_pulse_en = '1' AND v_count < i_pulse_count +1 then v_count := v_count + 1; end if; end if; end process CTRL;
rising_edge_pulse_run <= i_pulse_run and not i_pulse_run prev;
