I am new in automation electronics and in this forum.
I have this transfer function: \$G(s) = \dfrac{10}{(s+1) (s+5)}\$ and I was asked to create the circuit with 5 op-amps and the correct resistors and capacitors.
I don't know much about these kinds of electronics and any help would appreciated.
    \$\begingroup\$ Do you have any ideas about how to get started? Do you know any ways to make a circuit that implements part of the solution? \$\endgroup\$
    – The Photon
    Sep 25 '15 at 16:55
Here's a fairly straightforward hint or two....
Split the function into simpler parts like: -
\$G(s) = \dfrac{1}{s+1}\times \dfrac{1}{s+5}\times 10\$
Each simpler part is a functional block and when functional blocks are placed in series they multiply to give \$G(s)\$.
So, the easy one is a gain of ten block but how do you implement \$\dfrac{1}{s+1}\$.
Take a look at what a simple low pass filter does formed by a resistor and capacitor: -
Now I'm mentioning the RC LPF because I recognized it has a transfer function similar to \$\dfrac{1}{s+1}\$. You can go and derive it if you want but there is enough info on the web to tell you that it is: -
\$\dfrac{V_O}{V_I} = \dfrac{\frac{1}{CR}}{s+\frac{1}{CR}}\$ if CR = 1 then you have one of the parts.
Hints over.
BTW, as an addition I think it can be done with two op-amps but if you want to use 5 there's nothing stopping you except the shame of it!
