I have never seen a component like these. The markings say "1UL25" or "10L25" on the first line and "++" followed by a "Z" in a circle with black lines coming out of the sides. Sorry the picture is a bit blurry, it is the best I can do.
Unknown components
What are they? I have searched around but haven't been able to find anything.
    \$\begingroup\$ Tantalum capacitors. 1 and 10 uF, 25V. Polarised like electrolytics, so connect "++" to +ve voltage. \$\endgroup\$
    – user16324
    Sep 25, 2015 at 21:51
These are tantalum capacitors.
I'm not positive, but I would assume that these are 1uF and 10uF, both with a 25V rating.
Tantalums are polarized, hence the "++" one one leg.
Oops, looks like I left the same info as @BrianDrummond's comment. Sorry Brian! If you post it as an answer then I'll delete this one.
  • \$\begingroup\$ No worries, you took the time to make it a proper answer. \$\endgroup\$
    – user16324
    Sep 25, 2015 at 22:39
