I am using PIC micro controller (PIC16F1846) with an external 8MHz crystal attached to the external clock pins (RA6 and RA7).
Why is it that when I use my oscilloscope probe to attempt to measure the clock frequency my basic LED flashing program stops working (light state freezes) and I have to perform a reset?
  • \$\begingroup\$ Do you connect your oscilloscope to RA6 and RA7 at the same time ? I mean, probe tip to one and ground to the other ? Do you use a proper 1:10 probe ? \$\endgroup\$ Commented Sep 29, 2015 at 13:49
9
Try a 10x (not 1x) probe on the OSC2 pin. You should be able to see the clock. The frequency will be slightly changed by the probe loading.
I don't think your part number is correct, but most 16F chips are similar.
Edit: Scope probe loading is explained in this Tektronix paper.
Crystal pullability is explained in this application note. Note that the typical loading from a 10x scope probe would only change the frequency by perhaps 100ppm (0.01%), which is unimportant in many applications other than timekeeping.
  • \$\begingroup\$ Your correct, the part is actually PIC16F1847. Using the probe in x10 worked! \$\endgroup\$ Commented Sep 29, 2015 at 13:54
  • \$\begingroup\$ Could you explain this idea of the probe loading affecting the frequency? \$\endgroup\$ Commented Sep 29, 2015 at 13:54
  • \$\begingroup\$ Please see edit above \$\endgroup\$ Commented Sep 29, 2015 at 14:10
  • \$\begingroup\$ pdf link isn't working for me. \$\endgroup\$ Commented Sep 29, 2015 at 17:26
  • \$\begingroup\$ @DanNeely Should be working now. Tek appended some stuff to the URL that maybe was intended to discourage deep linking. \$\endgroup\$ Commented Sep 29, 2015 at 20:13
9
This is a separate but related topic.
Measuring the frequency at the oscillator out pin tells you the oscillator frequency, not necessarily the instruction clock frequency. On old PICs, that was just 1/4 of the oscillator frequency. However, many newer PICs have more complicated clock chains than that, with a PLL and various optional dividers.
It is a good idea to make sure the instruction clock is actually what you think it is as early as possible. I usually do this by having my main loop initially just toggle a pin. Set up the bank for the appropriate LAT register first, then BSF, BCF, and BRA back to do it again. That should take 4 instruction cycles. You look at that on a scope and verify the pin frequency is really 1/4 of the instruction clock that you expected.
  • \$\begingroup\$ Although this doesn't directly answer my question it is a very good point and probably has saved me a lot of pain down the line. Thank you! \$\endgroup\$ Commented Sep 29, 2015 at 14:48
Capacity of the probe could cause failure of the clock generation. The simpliest way to prevent this is to wire a resistor to the central contact of the probe and perform the measurement placing another leg of the resistor onto your crystal. 100 Ohms will be fine.
