I am using Bipolar stepper motor Haydon Kerk 25343-05. My driver IC is DRV8833. The micro controller I am using is ATXMEGA16A4U.
The bipolar stepper motor has 4 wires. 4 PWM output pins of Microcontroller go to the driver chip which in-turn drives the stepper motor.
The step angle of the motor is 7.5 degree. If I name the wires as A,B,C,D; what kind of input pattern should be given to drive the motor forward. Should I give delay after each step, If so, how much delay should I give?
I'd call these signals A1-A2-B1-B2 (as in the datasheets).
For the pattern:
0101->1001->1010->0110->0101... the motor will rotate one direction and for
0101->0110->1010->1001->0101... it will go the other way.
If you add a delay between steps it will just rotate slower.
  • \$\begingroup\$ There is no datasheet for the motor, where did you find it? Can I use GPIO to generate the pattern instead of PWM ? \$\endgroup\$
    – Pradeep Ch
    Sep 30, 2015 at 0:46
  • \$\begingroup\$ I was taking about the DRV8833 driver datasheets. You really don't need the datasheets for your motor as it has only four wires. Just make sure that you connect the 2 wires from one coil to A1 & A2 and the other coil to B1 & B2. If you switch the 2 wires from one or the other coil or flip the coils all together, the motor will just spin the other direction. \$\endgroup\$
    – Alexxx
    Oct 1, 2015 at 0:03
  • \$\begingroup\$ I just noticed that you were also asking about the PWM vs GPIOs. You don't use PWM with stepper motors. Just 4 GIPOs \$\endgroup\$
    – Alexxx
    Oct 1, 2015 at 23:34
  • \$\begingroup\$ Can you watch this video : youtube.com/watch?v=kAyDmovM18E . It has the stepping sequence for bipolar stepper motor. Coil A is energized and then B. The sequence appears: (A1 B1 A2 B2): 1010 0101 (-1)0(-1)0 0(-1)0(-1) ... I used '-1' to use reverse current direction. Your pattern does not appear here, How did you find the pattern? \$\endgroup\$
    – Pradeep Ch
    Oct 2, 2015 at 11:50
  • \$\begingroup\$ Ok. My sequence showed you how to set 4 GPIOs outputs that are connected to your driver. For coil A terminals A1A2=01 means that the current is flowing one direction (A1=gnd A2=vcc) while A1A2=10 means that it's in the opposite direction (A1=vcc A2=gnd). It's the same for coil B. A general rule is that you flip only one coil's current in each step, never both. That's all you have to know. \$\endgroup\$
    – Alexxx
    Oct 3, 2015 at 13:20
