17
I am making a obstacle avoiding robot and wanted to power it with mobile phone batteries. But wondering how to solder wires on battery correctly for no inconvenience.
p.s. I am a new arduino enthusiast.
  • 22
    \$\begingroup\$ You better don't, they don't like heat \$\endgroup\$
    – PlasmaHH
    Commented Sep 30, 2015 at 9:34
    \$\begingroup\$ Just as an aside to the safety side, bear in mind that a '5V' battery is likely to output anywhere between 8 and 3V, depending on charge level. If you need 5V within say 10%, then you will need to regulate the battery output. \$\endgroup\$
    – Oliver
    Commented Sep 30, 2015 at 11:36
  • \$\begingroup\$ Mobile phone batteries operate in the 3-4.2V range. \$\endgroup\$
    – pjc50
    Commented Sep 30, 2015 at 13:40
  • 13
    \$\begingroup\$ As an aside, the safe way to do this is to buy a USB power pack. It will give you nice 5V output and have all the necessary protection and charging circuits built-in. \$\endgroup\$
    – jpa
    Commented Sep 30, 2015 at 16:20
    \$\begingroup\$ @jpa already made the point I was going to under all the alarmist talk; namely the contacts could very well be on a PCB which is fine to solder to (if you're quick). But I'd just point out that you can buy a lithium battery from HobbyKing with a handy connector with more capacity than a cell phone battery for maybe $8. \$\endgroup\$
    – Nick T
    Commented Sep 30, 2015 at 21:08
6 Answers 6
21
Step one is trying to avoid wanting to solder to any kind of pre-fab battery, as you don't know 100% for sure what's in them in ways of protection.
Step two is really thinking hard if you can't stick to step one.
Step three would be: Very, very carefully.
To expand on step three:
Many single-purpose pre-fab lithium cells for such things as phones will have very limited protection, if any at all, against short circuit or internal discharge avalanches and what not, and will generally have 99% battery in them, so the chemistry will be close to the contacts.
So over-heating is a serious danger, as that can damage the internal barriers and cause excessive internal leakage, which can quickly cascade into a damaged battery, or one just about ready to explode. For circular, metal-can cells this risk is very low, due to construction, but for flat LiPo cells, with low thermal mass at the pins as well, this is a good possibility.
Apart from that a short circuit on the pins while you are soldering is also a very serious risk. The plastic that holds the contacts will be extremely low grade, so if you heat the pins for more than a second or two, they may come loose and presto-sparking.
Short circuiting a LiPo cell with no internal protection may also cause outgassing or explosion if you are unlucky, both potentially seriously shortening your life expectancy.
The one advantage to this is that most cell phone batteries come with gold plated contacts and solder should fairly easily stick to them.
I repeat: Try step one twice and then seriously think hard about step two!
But if you MUST: First practice soldering small contacts a couple of times to get competent at it and only then try soldering onto the cell, making sure you never heat the contacts for long stretches.
But seriously don't
    \$\begingroup\$ In my experience, designed-to-be-replaceable batteries generally have quite good protection circuits in them. At least as reliable as a random "protected" Trustfire/Surefire cell would have. It kind of makes sense as people are expected to handle them and perhaps sometimes accidentally shortcircuit them. \$\endgroup\$
    – jpa
    Commented Sep 30, 2015 at 16:18
    \$\begingroup\$ I think the danger is that the phone circuitry offers some of the protection and the cell itself needs less. it makes the replaceable part cheaper as the protection is in the phone. I have seen both types, some with no protection and others with comprehensive protection. Size seems to play a role with smaller cells having less internal smarts. \$\endgroup\$
    – KalleMP
    Commented Jul 24, 2016 at 21:15
45
Don't.
The battery manufacturers specifically tell you not to do this, as the batteries are quite heat-sensitive. If you manage to set one on fire, you can't extinguish it either: it reacts explosively with water, so you have to bury it in sand or powder.
The correct solution is to get spring-loaded contacts or "pogo pins", attach them to a PCB or piece of Veroboard, then attach the wiring to that. You can then either build a battery holder nicely or use tape or elastic bands to hold it in place.
(The manufacturers use electric or ultrasonic spot welding to attach wires to battery terminals internally.)
    \$\begingroup\$ The factory-made phone ones I've seen (taken apart) have some kind of welded (!!) connection between the cell and the "smart" PCB. I've always wondered what kind of welding that is... And here's article about this: dx.doi.org/10.1080/09507116.2011.606148 \$\endgroup\$ Commented Sep 30, 2015 at 9:55
    \$\begingroup\$ Since some of you I suspect don't have access to a university library, here's a quote from the article: "Small-scale welding is characterized by sharp process parameters, and thus a relatively high-current intensity and very short welding time (milli- and micro-seconds). With such parameters, joined workpieces become warm only from the pressure of the electrodes, and the heat-affected zone is very small." The pressure needed is quite high though, about 0.7MPa. \$\endgroup\$ Commented Sep 30, 2015 at 10:09
  • \$\begingroup\$ @RespawnedFluff the question is: "Can I solder to them?" The answer is: "Better not". Spot welding is something entirely different than plopping a ball of molten metal onto something. \$\endgroup\$
    – Asmyldof
    Commented Sep 30, 2015 at 10:20
  • \$\begingroup\$ @Asmyldof: Yeah I know, but the answer mentioned how it's actually kosher to do it... I thought someone might be interested in details. Here's what it looks like: youtu.be/m86qwHKGXZc?t=221 \$\endgroup\$ Commented Sep 30, 2015 at 10:24
  • \$\begingroup\$ @RespawnedFluff My apologies, misread your intentions :-) \$\endgroup\$
    – Asmyldof
    Commented Sep 30, 2015 at 11:07
21
There are Li-ion batteries and battery packs designed specifically to be soldered, which usually look like this:
I'd strongly suggest you buy one of these instead of trying to reuse a cell phone battery. Your device will most probably be badly soldered and thus unreliable if you do. There's aslo a danger of shorting or overheating the battery while holding it right in front of your face. Lithium is not that good for the eyes they say :)
If you already have the batteries, pogo pins are the way to go.
Use conductive glue. Here's an example. A few caveats, taken from the reviews:
  • It isn't tacky.. so either use a clamp, or be prepared to hold the object (for a long time.) It's thin & watery..apply sparingly in layers. ...and even after it's dried to the touch, it won't conduct electricity very well until it's sat for at least a few days to thoroughly dry.
  • It gets brittle.. and will crack away under any kind of stress or tugging.. so be prepared to reinforce whatever you're mending with either tape or an additional application of epoxy.
  • \$\begingroup\$ with either tape of an additional application of epoxy — some of these ofs should have been or it seems. \$\endgroup\$
    – Ruslan
    Commented Sep 30, 2015 at 15:51
6
If the battery is replaceable and has gold-tinned pads like this: Nokia cell phone battery
Then they have protection circuit and the pads are on a small PCB. You can solder to these pads like you would to any PCB (don't use more heat than needed, but it is not particularly sensitive).
However, if it has wires or connector directly coming from the battery, like this: iPhone battery
Then the battery most likely does not have protection circuit so you probably should avoid using it at all. If you do, you can carefully solder to the wires but never on the battery itself.
  • \$\begingroup\$ The problem is the "most likely" part. Remember that failing in the guess can lead to a very serious fire. \$\endgroup\$
    – yo'
    Commented Oct 3, 2015 at 15:11
  • \$\begingroup\$ @yo' The "most likely" was only in the second case, which one probably should avoid anyway. But yeah, li-ion batteries can lead to serious fires in any case. It happens pretty often with commercial products also. \$\endgroup\$
    – jpa
    Commented Oct 3, 2015 at 18:49
Been doing this off and on for years.
  1. Make sure the battery terminals are very clean.
  2. Take off insulation from the wires you are going to use about 20mm.
  3. Apply lots of solder to the bare wire.
  4. Have the end of the wire pointing down and apply more solder until it starts to form a drop on the bottom, drop diameter must be smaller than the contact pad on the battery.
  5. Put battery gently in a clamp with contacts uppermost and level.
  6. Cut end of wire halfway through solder drop on end.
  7. Present wire vertically to battery contact pad. Heat up wire with HOT soldering iron from point approx 10mm from end.
  8. Solder blob melts onto contact remove iron and wait for solder to set.
  9. Use connection as required. Sure, its not the best and not following best practice but works for me.
