I know that mathematically the k-V analog input on an A to D converter could be converted to the digital code of \$\dfrac{k(2^n-1)}{VDD}\$. But I really don't understand where it comes from and the logic behind it. Any help would be appreciated.
\$\begingroup\$ The values of a n-bit number range from 0 to 2**n-1. \$\endgroup\$ – Ignacio Vazquez-Abrams Sep 30 '15 at 11:54
\$\begingroup\$ yes but how we get to that formula in the question? \$\endgroup\$ – Jack Sep 30 '15 at 11:56
\$\begingroup\$ The minimum value is represented by 0V and the maximum value is represented by Vdd. The rest is just linear interpolation. \$\endgroup\$ – Ignacio Vazquez-Abrams Sep 30 '15 at 11:57
2\$\begingroup\$ I think my problem was that I didn't realize that the value of the 1024 level is 1023 because it is all ones. I think I get it now. Let me know if I am right. \$\endgroup\$ – Jack Sep 30 '15 at 12:55
2\$\begingroup\$ You are correct. \$\endgroup\$ – Alexxx Sep 30 '15 at 13:40
My problem was that I didn't realize that the value of the 1024 level is 1023 because it is all ones.
