Is there any simple (not the best one) way to detect the lowest value of a signal, like a diode and capacitor detect the peak value, I want to do it for detect the lowest value of a signal.
  • \$\begingroup\$ You should basically just reverse the diode. \$\endgroup\$ – Justin Sep 30 '15 at 19:37
  • \$\begingroup\$ So you have to first charge the capacitor to the max value right? isnt there any problem with current flowing in that direction? \$\endgroup\$ – Pulse9 Sep 30 '15 at 19:39
  • \$\begingroup\$ Can you put up the schematic you're thinking of? \$\endgroup\$ – Justin Sep 30 '15 at 19:41
  • \$\begingroup\$ Look for a peak detect circuit. (the "peak can have either polarity... you'll have to reverse the diode as Justin said.) \$\endgroup\$ – George Herold Sep 30 '15 at 19:42
  • \$\begingroup\$ What do you mean by"lowest value"? - Do you mean the most negative value or the lowest level of an AC signal such as audio? \$\endgroup\$ – Kevin White Sep 30 '15 at 20:27
Press and release the START button when you want to monitor the circuit. MIN will be the minimum voltage output (less the forward diode drop) since start was last released.
  • \$\begingroup\$ Nice :), so you press the button the capacitor charge, then when you have a lowest value than the capacitor in V1, the capacitor discharge right? \$\endgroup\$ – Pulse9 Sep 30 '15 at 20:29
  • \$\begingroup\$ Exactly. But remember that there is always a forward voltage drop across a diode, so you must account for this when reading MIN. \$\endgroup\$ – bigjosh Sep 30 '15 at 20:41
