I have a PIC starter kit. I am doing a simple program of turning on led when switch is pressed and then turning them off when switch is released like following:
if(switch==1)
  led = 1;
else
  led = 0;
I was actually not able to do above code in MPLAB. Then I found a tutorial online. I used that code and it was working.
Switch is connected to RD7
Led is connected to RD0
CODE
if(PORTAbits.RD7 == 0)
  PORTDbits.RD0 = 1;
else if(PORTAbits.RD7 == 1)
  PORTDbits.RD0 = 0;
Now I am confused. Why led is turning on when switch(RD7) is low. Can anyone explain me this logic.?
You should refer to the User Guide. It says that
Push button switches provide the following functionality:
• SW1: Active-low switch connected to RD6
• SW2: Active-low switch connected to RD7
• SW3: Active-low switch connected to RD13
also
The switches do not have any debounce circuitry and require the use of internal pull-up resistors; this allows you to investigate software debounce techniques.
So I think this answers your question of why led is turning on when switch(RD7) is low
If you read the documentation for your board, you will see the following, which I think is self explanatory:
doc
