I wonder how a multi-bytes instruction is executed when there is only 16-bit data bus? Assume the instruction is MOV AX,[10H]. The machine code of this instruction is 3 bytes. By combining the CS:IP registers, a 20-bit address is generated and there three bytes (which represents the machine code of that instruction) is accessed.
        CS:IP -> +-----------+
                 |    A0     |
                 |    10     |
                 |    00     |
As you can see, we have to put A01000 on the data bus.
    \$\begingroup\$ I'm guessing it needs multiple cycles to fetch the whole instruction (if I'm understanding your question correctly). \$\endgroup\$
    – tangrs
    Oct 1 '15 at 12:18
Intel 8086 processor doesn't execute commands directly from data bus. Instead, commands at CS:IP are fed into 6-byte prefetch queue and executed from there. This queue was specifically designed to accommodate a complete instruction, and the maximum instruction length on 8086 is limited to 6 bytes.
  • \$\begingroup\$ Yeah, bad phrasing. Certainly the instruction length was used to define the queue size, not the other way around. \$\endgroup\$ Oct 1 '15 at 13:54
