I am new to microcontrollers. I modified the Adc_Soc Example, such that CPU Timer 0 triggers ADCINA7. CPU Timer 0 is configured with 60MHz and period is 2 seconds. Also I increment a variable(LoopCount) inside adc_isr.
My doubt is, if I am triggering the SOC8 with CPU Timer 0 for every 2 seconds, then the variable(LoopCount) should increment every two seconds. But here it increases rapidly in 1000s within a second. Why is it so? And please correct me if I am wrong.
Edit 1 : Instead of declaring and defining the Interrupt _isr in the main.c, I used the f2802x_defaultisr.c and now the ADC register value is updated every 2 seconds. But still I don't know where I went wrong with the previous code(interrupt_isr in main.c). Please help me.
#include "DSP28x_Project.h" // Device Headerfile and Examples Include File
// Prototype statements for functions found within this file.
interrupt void adc_isr(void);
//interrupt void cputimer0_isr(void);
void Adc_Config(void);
// Global variables used in this example:
volatile uint16_t Voltage;
uint16_t LoopCount;
main()
// WARNING: Always ensure you call memcpy before running any functions from RAM
// InitSysCtrl includes a call to a RAM based function and without a call to
// memcpy first, the processor will go "into the weeds"
#ifdef _FLASH
memcpy(&RamfuncsRunStart, &RamfuncsLoadStart, (size_t)&RamfuncsLoadSize);
#endif
Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP2803x_SysCtrl.c file.
InitSysCtrl();
// Step 2. Initialize GPIO:
// This example function is found in the f2802x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
InitGpio(); // Skipped for this example
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
DINT;
// Initialize the PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the f2802x_PieCtrl.c file.
InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
IER = 0x0000;
IFR = 0x0000;
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example. This is useful for debug purposes.
// The shell ISR routines are found in f2802x_DefaultIsr.c.
// This function is found in f2802x_PieVect.c.
InitPieVectTable();
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
EALLOW; // This is needed to write to EALLOW protected register
PieVectTable.ADCINT1 = &adc_isr;
// PieVectTable.TINT0 = &cputimer0_isr;
EDIS; // This is needed to disable write to EALLOW protected registers
// Step 4. Initialize all the Device Peripherals:
// This function is found in f2802x_InitPeripherals.c
// InitPeripherals(); // Not required for this example
ConfigCpuTimer(&CpuTimer0, 60, 2000000);
CpuTimer0Regs.TCR.all = 0x4001; // Use write-only instruction to set TSS bit = 0
InitAdc(); // For this example, init the ADC
// Step 5. User specific code, enable interrupts:
// Enable ADCINT1 & CPUTIMER0 in PIE
PieCtrlRegs.PIEIER1.bit.INTx1 = 1; // Enable INT 1.1 in the PIE
PieCtrlRegs.PIEIER1.bit.INTx7 = 1; // PIE Group 1 Vector INT1.7 --> CPU Timer 0
IER |= M_INT1; // Enable CPU Interrupt 1
EINT; // Enable Global interrupt INTM
ERTM; // Enable Global realtime interrupt DBGM
LoopCount = 0;
// Configure ADC
//Note: Channel ADCINA4 will be double sampled to workaround the ADC 1st sample issue for rev0 silicon errata
EALLOW;
AdcRegs.SOCPRICTL.bit.SOCPRIORITY = 0; // SOC Priority is handled in round robin mode
AdcRegs.ADCCTL1.bit.INTPULSEPOS = 1; //ADCINT1 trips after AdcResults latch
AdcRegs.INTSEL1N2.bit.INT1E = 1; //Enabled ADCINT1
AdcRegs.INTSEL1N2.bit.INT1CONT = 0; //Disable ADCINT1 Continuous mode
AdcRegs.INTSEL1N2.bit.INT1SEL = 8; //setup EOC8 to trigger ADCINT1 to fire
AdcRegs.ADCSOC8CTL.bit.CHSEL = 7; //set SOC8 channel select to ADCINA7
AdcRegs.ADCSOC8CTL.bit.TRIGSEL = 1; //set SOC8 start trigger on CPUTIMER0
AdcRegs.ADCSOC8CTL.bit.ACQPS = 6; //set SOC8 S/H Window to 7 ADC Clock Cycles, (6 ACQPS plus 1)
GpioCtrlRegs.GPBMUX1.bit.GPIO34 = 0;
GpioCtrlRegs.GPBDIR.bit.GPIO34 = 1;
EDIS;
// Wait for ADC interrupt
while(1)
Voltage = AdcResult.ADCRESULT8; //discard ADCRESULT0 as part of the workaround to the 1st sample errata for rev0
GpioDataRegs.GPBTOGGLE.bit.GPIO34 = 1;
AdcRegs.ADCINTFLGCLR.bit.ADCINT1 = 1; //Clear ADCINT1 flag reinitialize for next SOC
PieCtrlRegs.PIEACK.all = PIEACK_GROUP1; // Acknowledge interrupt to PIE
LoopCount++;
if(LoopCount == 38000)
LoopCount = 0;
return;
