I designed a board to mux 16 inputs into a 4 channel scope using relays. I also included circuitry to replicate a 10x probe on the board. That is, I placed a 9M ohm resistor in parallel with a 1.4pF variable cap. These values came from a 9:1 ratio with the oscilloscopes internal 1M ohm resistor and a 13pF cap. From there, a BNC cable connects the board and the scope.
Here is a schematic:
PV1, PG1, PI1, PV2, PG2, PI2 are all attached to 4 separate normally open relay contacts.
When I went to tune the capacitors for a 1kHz square wave, the wave was completely scewed and no cap value from .9pF to 9pF would fix it. To my surprise I realized that the wave looked the best at the upper value (around 10pF) instead of near 1.4pF like I had expected. I replaced it with a 22pF cap out of curiosity and the square wave looked quite a bit better - not perfect - but also has a slight DC offset.
Any ideas what is going on here? Is the problem with the BNC cable, or possibly inductance / capacitance of the circuit. How should I have designed this in the first place?
FYI: There is no ground plane because each have slightly different grounds. Also, I injected the square wave directly on the cap, with ground connected to the BNC ground. I get the same result when injecting from anywhere else.
Here is some waveforms on the scope. From top to bottom: No cap installed, around 10pF, and the bottom is 22pF.
Also, comparing the signal with the original square wave. enter image description here
Update: Thanks for the answers. Someone suggested I use a circuit such as below to create a 100x probe. Would this work better?
    \$\begingroup\$ Maybe you have already seen this but if not, have a look at: youtube.com/watch?v=OiAmER1OJh4 probably in your case what is bugging you is that the connection from the probe to the scope is not a transmission line and/or it is but it might not be properly terminated. \$\endgroup\$ Oct 2, 2015 at 12:44
  • \$\begingroup\$ My pleasure, even after working with oscilloscopes for 25 years, I learned something from that video :-) \$\endgroup\$ Oct 2, 2015 at 19:04
The thing you are missing is the fact that the cable on a scope probe is NOT ordinary low-loss coax, mainly because it would be difficult to make a usable piece of coax that has a Z0 (characteristic impedance) of 1 MΩ that would match the input impedance of the scope.
Instead, scope probe cable is a special lossy cable that minimizes the effects of reflections over its length. It also helps mitigate the effects of the cable's own capacitance.
If you want to use regular coax, you'll need to match the outputs of your attenuators to the impedance of the cable (a buffer amplifier is the most direct approach), and use the 50 Ω terminations on the scope's inputs.
  • \$\begingroup\$ I agree that scope probes use coax with a small gauge resistance wire but at these frequencies you don't need to match the cable to the scope - just take account of its capacitance in making the compensated attenuator. \$\endgroup\$ Oct 2, 2015 at 11:42
  • \$\begingroup\$ Thanks for the reply. It might be difficult to add a buffer amplifier to my board at this stage though. What do you think of the circuit I added at the end of my original post. Would something like that work better? Cheers \$\endgroup\$ Oct 2, 2015 at 17:55
You did not take into account the capacitance of the cable and wiring - they will increase the required capacitance.
Since you need to add about 20pF beyond your calculation it It looks like the other capacitances add another 180pF beyond the capacitance of the scope (9 * 20)
Edit.
I had the connections backwards in my mind. It is the capacitance of the coax to the scope that is the problem. RG58 is about 25pF/foot. So 6-7 feet of coax would cause what you are seeing.
You can reduce the effect by using a shorter cable.
What maximum frequencies are you concerned about?
As Dave Tweed mentions if you need to do very high frequencies using a buffer amplifier and a 50 ohm terminated system would be better.
  • \$\begingroup\$ But the relays, etc. are upstream of the attenuators -- they should have no effect on the performance of the attenuators themselves. There's a different problem that I've pointed out in my answer. \$\endgroup\$
    – Dave Tweed
    Oct 2, 2015 at 11:34
  • \$\begingroup\$ Yup, I misread the drawing. However I think it is still the extra capacitance on the scope side that is the problem. \$\endgroup\$ Oct 2, 2015 at 11:40
  • \$\begingroup\$ Ah I see, the cable capacitance is added to the scope capacitance so I want to use (cable capacitance + scope capacitance)/9.. For some reason I thought the inductance and capacitance in those cables balances out in such a way that it electrically looks resistive. I guess not? If it was pretty accurate between 0 and 5MHz that would work fine for my needs. How could one calculate this? \$\endgroup\$ Oct 2, 2015 at 17:38
