My teacher was teaching me about analog multiplier and divider using opamp. Following is the circuit is made us write.
Could someone please explain me how is it working and where it is used. A little detail and further reading source is appreciated.
The circuit is based on (and can be seen as) a simple inverting opamp circuit. In general:
Acl=-Hf/(1/Aol+Hr) and for Aol infinite (ideal opamp) Acl=-Hf/Hr with
Acl: Closed-loop gain, Aol:Open-loop gain
Hf: Input signal portion available at the inv. input (Vout=0);
Hr: Output signal portion available at the inv. input (Vin=0).
In our case: Hf=1/2 and Hr=Vr/2.
Therefore: H(s)=-1/Vr
Special case: Vr=1 with H(s)=-1 (as known from simple inverter circuit).
The circuit shows an inverting opamp configuration, thus both the terminals of the opamp are at the same potential(ie 0 V). Now the current through the resistor connected to the source Vz is I = Vz/R. Since the opamp input draws no current ideally, this current through the resistor R connected to on of the inputs of the multiplier resulting in the input voltage of -Vz at the multipliers input.The product of -Vz and Vy is then multipliers output which gts inverted due to the opamp configuration.
  • \$\begingroup\$ Multiplier direction is opposite to what you've taken. I've updated the diagram. How is it working as a divider? \$\endgroup\$ – Vedanshu Oct 2 '15 at 17:10
