I have a 1Vpp 1Hz repetitive arbitrary wave signal that resides entirely above the DC line. IOW there is no negative-going excursion. This is output from an LM358 inverting op amp buffer powered between +12VDC and ground (0V) rails.
I would like to feed this into an LM358 op amp with a gain of 10 that is powered in a non-standard way as follows. Its "positive" rail is set at 0V. The "ground" rail is set at -12VDC. There is a reason for this, and I do not want to change it.
When I connect the signal from the positively powered buffer op amp to the negatively powered gain stage op amp there is no output, presumably due to the DC level mismatch.
I have seen circuits that shift signals to a higher positive DC level, but not any that shift a positive signal into a negative region. Some level shift circuits also include a capacitor in the signal path, which I would prefer to avoid due to fidelity issues at such a low frequency.
Can someone please provide a working circuit that will enable the gain amp to output the arb wave signal so that it swings between about -10 and 0V? A trimmer adjustment for the DC shift would also be helpful in case I decide to use reduced gain.
This has been a persistent design issue which, due to my limited knowledge, I have not solved so far, either by inquiring online or hours on the bench. Any assistance to get me over this hurdle would be greatly appreciated.enter image description here
  • \$\begingroup\$ Not possible as stated. You have a 2v P-P signal feeding a x10 amplifier, with the amplifier powered by a total of 12 volts. You cannot produce a 20 volt swing with a single 12 volt amp. \$\endgroup\$ Oct 3 '15 at 2:40
  • \$\begingroup\$ Sorry for my mistake. I have been working on this so long I tripped myself up. The input signal level is 1V not 2V. However, the intent of my question remains the same. e.g. how to shift the 1V buffer output to match the DC level of the gain amp input. Please see the simplified diagram I have added to my original post. \$\endgroup\$
    – P Nielsen
    Oct 3 '15 at 8:53
  • \$\begingroup\$ Not 100% sure about this, but in the colpits oscillator, you switch the phase with two caps. Look at it maybe it works. C2 and C3 here: learnabout-electronics.org/Oscillators/images/Colpitts-03.gif \$\endgroup\$
    – Sider
    Oct 3 '15 at 14:57
  • \$\begingroup\$ Thanks for the suggestion, but it does not apply to the conditions of my circuit. Can someone please help? \$\endgroup\$
    – P Nielsen
    Oct 3 '15 at 20:30
  • \$\begingroup\$ What rail do you want your output signal referenced to - ground? \$\endgroup\$ Oct 3 '15 at 21:14
Your buffer is in the inverting configuration so if you drive the input positive the output will always be tanked at GND. Also if you want the 10x amp to work inverted the positive terminal need referenced to GND.
