I am thinking of purchasing an LTS4680 seven segment display for one of my projects.Here is the datasheetdatasheet:http://www.icpdf.com/icpdf_datasheet_7_datasheet/LTS4680AE_pdf_1732299/LTS4680AE_datasheet.html
I understand that it is a common cathode 7 seg display, so ground should be connected to the common cathode pin.What pin is it?I'm not sure but i think it's pin 6 according to the diagram in the datasheet.Also what value of resistors do I need to connect to the anode(+) of each segment.My power supply is 5v at 0.6A(600mA).
