What will be voltage Vz in this circuit
I have tried to solve the equation using mesh analysis by taking i1 and i2 anti clockwise in upper and lower mesh respectively.
  • \$\begingroup\$ You need to post work if you want help understanding how to solve this. This isn't a do-my-homework site. \$\endgroup\$ – Iancovici Nov 3 '15 at 11:54
First, see that in the upper wire you have $$I_1=-2 Vx$$ and you can write: $$I_1 = I_2 + I_3$$, where I_2 is the current in the 2nd wire (from left to right) and I_3 is the current in the other one. Now, you have to "decide" where the Ground is and just solve equations.
Note that V_Z has the same voltage that the - of V_x. Using that, I got: $$I_2 = -\frac{V_Z + V_X}{R_2}$$ $$I_3 = \frac{15V - V_Z}{R_3}$$
If you don't know V_X, you can have it using that $$2V_X = I_2 + I_3$$
