I am trying to understand the PDF From the following URL: Spansion Application Note
Under the heading Flash Address Pin Labels, it describes that "In word mode there is no means to individually select a byte within a word".
Can someone explain why this behavior?
In Table-1 & Table-2 of the same document in one case A(-1) is shown as 0 and 1 respectively. Is there any correspondence between them or it fixed?
Thanks for your time. Best Regards, GSR
