I've been spending a lot of time trying to know why the gate voltage of M2 is 2Vt + 2Von. I know that if all transistors have the same characteristics then all the Vgs = Vt + Von. Can somebody explain me why it is 2Vt + 2Von?
Cascode Current Mirror
The gate voltage of M2 is the same as M4, equals the voltage at Iref input.
M4 sits on top of M3 that has a gate voltage of Vt+Von.
So the total a the Iref input = M4(Vgs) + M3(Vgs)
As you stated the Vgs of all devices is Vt+Von as they are all passing the same current so substitute in the above
Ref input = Vt+Von + Vt+Von = 2Vt + 2Von.
    \$\begingroup\$ Probably is a dumb question but I still dont see why the InputVoltage = Vgs3 + Vgs4? \$\endgroup\$
    – EMPV
    Oct 4, 2015 at 1:50
  • \$\begingroup\$ The drain of M3 connects directly to the source of M4. Think of each of M3 and M4 as just being a voltage source (a battery for example). They are just connected in series so the total voltage is the sum of the two. \$\endgroup\$ Oct 4, 2015 at 1:51
  • \$\begingroup\$ Yes. Be careful about mixing up the relative voltage terms and the voltages referenced to ground. \$\endgroup\$ Oct 4, 2015 at 1:55
  • \$\begingroup\$ So that means I can see each M3 and M4 as a diode connection and the voltage of each one is Vt + Von and the sum is 2Vt + 2Von? \$\endgroup\$
    – EMPV
    Oct 4, 2015 at 1:59
    \$\begingroup\$ That's right, you've got it. \$\endgroup\$ Oct 4, 2015 at 2:19
