Is Received Power and RSSI same thing? I have been looking into it and think they are the same. But please guide me the difference between them if they are not the same.
No it is not, RSSI only gives an indication of the received power. If you would have a large interfering signal on the same channel or an adjacent channel your RSSI value would be high yet the Received Power of the wanted signal would be low.
For proper receiver power measurements you will need a power meter or a spectrum analyzer.
Yes, it is. Now be careful, signal strength will not tell you the whole story, you have to look at the LQI (Link Quality Indicator) also. You can have a high RSSI but also have high noise in your signal.
  • \$\begingroup\$ Is LQI similar to SNR ? \$\endgroup\$
    – Umar
    Oct 6, 2015 at 7:08
  • \$\begingroup\$ Sort of, but not exactly. It is a measure of the signal strength vs the number of errors received. \$\endgroup\$
    – davidrojas
    Oct 6, 2015 at 7:17
