I would like to create a circuit board that can toggle between 3 states, only with the press of a button.
So when pressing the button, the board should go to the next state, and at the last state, should loop back to the first.
The 3 states are like this, using 2 LEDs:
  1. LED 1 is on, LED 2 is off
  2. LED 1 is off, LED 2 is on
  3. Both LEDs are off
Can I create a simple circuit board that can do this? If so, how would it be designed?
(Disclaimer: I only know high-school electronic stuff, but I can solder pretty well)
    \$\begingroup\$ Can you use microcontrollers? \$\endgroup\$
    – Laki
    Oct 6, 2015 at 7:43
  • \$\begingroup\$ Yes, but I'd like to keep it simple and compact, so no arduino things. \$\endgroup\$ Oct 6, 2015 at 7:45
  • \$\begingroup\$ Use PIC16F84 or similar. Use switch statement in C and your problem is solved. \$\endgroup\$
    – Laki
    Oct 6, 2015 at 7:48
    \$\begingroup\$ Use a 3 bit shift register (eg part of 74LS95). Initialise it to 001 with a 'power on reset' to force parallel load - first and second bit drive your LED's third bit feeds back to DS1 (serial input) - use your button (de-bounced) to provide the 'clock' \$\endgroup\$
    – Icy
    Oct 6, 2015 at 7:57
  • \$\begingroup\$ @Icy: I suggest you move that to an answer. \$\endgroup\$ Oct 6, 2015 at 9:51
A 4017 decade counter will do the job. No LED on output 0, LED 1 on output 1, LED 2 on output 2 and reset connected to output 3. You could base it on the first circuit here - http://www.clarvis.co.uk/version2/4017.html
Initialise it to 001 with a 'power on reset' to force parallel load - a capacitor / resistor on the pin will do this.
Use the first and second bit outputs to drive your LED's. feed the third bit back to DS1 - the serial input
You will need to de-bounce the button - probably using a simple RC filter - and use that to provide the 'clock' to shift the signal on.
