I haven't studied electrical engineering however I am currently studying about Moore's law.
I found an answer to why transistors keep increasing but I still can't get my head around why so many are needed for dynamic RAM.
It says 6 transistors are needed for each bit in dynamic RAM.
What exactly do these 6 transistors do? Are the used to actually store and hold the data since it is volatile?
Sorry for the stupid question but I really can't get my head around it.
Assuming that by "dynamic RAM" you are referring to DRAM, it is the first time I hear about "6 transistors per DRAM bit".
DRAM's bit is usually implemented in the following way (or some slight variation on it):
As you can see, there is just one transistor and one capacitor here. Since capacitors in integrated circuits also have "transistor-like" structures (at least in MOSFET technologies), you could say that DRAM cell consist of two transistors.
However, in order to support DRAMs structure and functionality there is a standard "framework" which is required: sense amplifiers, repeaters, logic for refreshing the contents of DRAM, bit-line/word-line selectors etc. It is this "framework" which makes DRAM unacceptable for small volume storage - you need to provide the entire "framework" even for DRAM of size 1kB, which makes this 1kB storage too big and too power consuming.
However, if you make DRAM storage large enough, the standard implementation of 2 transistors per bit compensates for the "cost" of the framework.
In order to be completely accurate, we could account for the increase in "framework" size as a result of increased storage area. For example: it is evident that you'll need stronger sense amplifiers if your DRAM is not 1kB, but 1GB. Even then, I'd speculate that the "cost" of one additional DRAM bit is not higher than 3-4 transistors.
As for what the transistor does... In simple words: transistors behaves like an open-closed switch in the above configuration. When the transistor is "open" (i.e. not conducting) - the charge on the capacitor does not change, thus the level of the voltage does not change, thus the logical value of this bit does not change. When the transistor is "closed" (i.e. conducting), the voltage of the capacitor can be either probed (i.e. read the value of this bit), or changed (i.e. write a value to this bit).
Maybe you meant a static RAM, for which there's a well known 6 transistor version: see also https://en.m.wikipedia.org/wiki/Static_random-access_memory
6T SRAM cell
Transistors M1-M4 are the core of the cell, whereas transistors M5 and M6 are the access transistors.
