Drawing the land pattern for a through hole part and am seeing this extra information below the main hole diameter (and tolerance):
For example, let's look at the one drawn right below the LED symbol (this is for a RJ45 connector with embedded status LEDs). I see the main part is diameter 0.89mm but...
- What is the 0.035mm beneath it?
- What does PLC stand for? It's not the first time that one has showed up on these datasheets, but I cannot for the life of me find the meaning of this acronym. I noticed the diameter was quite small, so wondering if this is a pilot hole location. My guess was "pilot location center" but that turned up nothing in Google either.
- What are the numbers beneath that, in the box, with the ZYX?
Have always had PCB components fit my landing pads, so curious what the engineer was trying to communicate with all this seemingly extraneous info.
Note: It is unfortunate that the word PLC means something else regarding electronics. That has made searching for this on stackexchange or elsewhere practically impossible with all the noise.
Thanks for the future edification!
