The manual of ULP says that this command "Defines an empty stretchable space in a box layout context". It gives the below trivial example:
   dlgHBoxLayout {
     dlgStretch(1);
     dlgPushButton("+OK")    { dlgAccept(); };
     dlgPushButton("Cancel") { dlgReject(); };
This would be used as part of a bigger script containing dlgDialog. The thing is that changing the value of the parameter passed to this function makes no different at all. I am confused what this function is supposed to be used for.
The stretch factor does not matter when there is only a single space.
For multiple stretchable spaces, the factor specifies how much of the available space is allocated to each space object.
Try something like this:
dlgHBoxLayout {
  dlgStretch(1);
  dlgStretch(2);
  dlgStretch(3);
| improve this answer | |
