Since you've added a simulation in that (fairly terrible) web sim... If you change the min and max values for the opamp output to some sensible values (right click on the opamp to do that), you'll see that subsequently V- gets very close to 0 (some microvolts). You've set the rails of the opamp to +2 and -2V, so it's saturating, that's why the inputs are fairly far apart. Set the opamp rails/limits to something like +15 and -15V.
I have no idea if this link will show (or not) the edits I've made reflecting the above, but hopefully it does.
Here's a blow-by-blow how to solve it by hand (no system of equations needed):
- Calculate the current through the leftmost 10-ohm resistor since you know the potentials of both its ends (V- really is 0 because the [ideal] opamp is configured only with negative feedback).
- The current through the 20-ohm resistor is going to be same as the one though the leftmost 10-ohm resistor (since there's no current flowing into the [ideal] opamp pins)
- Calculate the voltage at the T-join of the 3 resistors using Ohm's law for the 20-ohm resistor.
- Calculate the current through the 40-ohm resistor since you now know the potentials of both its ends.
- Add the currents for the 20- and 40-ohm resistors to obtain the current through the right-most 10-ohm resistor
- Calculate the voltage at Vout by using Ohm's law for the right-most 10-ohm resistor; you've calculated the current through it in the previous step and you know the potential at the T-joint from the 3rd step.
