Referring [This Link] (I2C: Unable to Read Multiple Byte using Bit-Banging method).
I created an I2C BitBanging library for Pic16f877A. But I am unable to Read/Write the EEPROM.
My Pin Configuration are :
SCK : RB0
SDATA_OUT : RB1
SDATA_IN : RB2
Rest code remains the same.
Possibly, The issue could be of the delay function as I am using OSC = 11.0592 MHZ with Pic16f877A. but tried increasing the delay by 2 times. Issue remains the same.
Also,
#pragma config  FOSC    =   HS
Can any one help me with Possible issues and way to rectify the issue.
Note: Code remains the same as the link says. Only Pin and its required registers are changed for Pic16f877A.
  • \$\begingroup\$ Have you looked at the SCL and SDA lines with a scope? \$\endgroup\$ – tcrosley Oct 7 '15 at 12:34
  • \$\begingroup\$ I haven't read the datasheet for that EEPROM but isn't ~11MHz a bit fast for I2C? \$\endgroup\$ – Roger Rowland Oct 7 '15 at 12:56
  • \$\begingroup\$ @RogerRowland, thanks for your suggestion. As you suggested, I checked the maximum frequency for I2C is 400KHz. I can't change the Oscillator, so what would be the better way to calculate the delay ?? \$\endgroup\$ – skg Oct 7 '15 at 13:14
  • \$\begingroup\$ @skg Just insert delays into your bit banging code. \$\endgroup\$ – Roger Rowland Oct 7 '15 at 13:18
  • \$\begingroup\$ @RogerRowland, I am already using delay in my code. Just I need to increase the delay time. But How much , that i need to calculate. \$\endgroup\$ – skg Oct 7 '15 at 13:46
If all the code is exactly the same you have a mistake here :
#define Crystal_Value       8          // MHz
you should replace this line by:
#define Crystal_Value       11          // MHz
at the condition 11MHz is really the value of your system oscillator and not the only the one of your crystal oscillator.
  • \$\begingroup\$ thanks for your response. I already did this. " #define Crystal_Value 11.0592 //MHz " \$\endgroup\$ – skg Oct 8 '15 at 4:22
  • \$\begingroup\$ Is 11MHz the frequency of your crystal or the frequency of your system? Some key word defines it \$\endgroup\$ – damien Oct 8 '15 at 8:38
  • \$\begingroup\$ Its Crystal Frequency \$\endgroup\$ – skg Oct 8 '15 at 13:10
Finally I caught my mistake.
Link provide just works fine. It was my mistake. While modifying the functions call, I deleted initI2C() function call. Which was causing the issue.
Also, Crystal value should be
#define Crystal_Value       12          // MHz
Thanks everyone for your valuable suggestions, that helped me improving my code.
