It may be that you're having a hard time with the air-cored coil because its resistance is spoiling its Q.
The surest way to find the inductance of the coil in-circuit is to sweep the input of the circuit with a sine wave and look for a peak across the LC. That peak will occur at resonance, when the reactances of the cap and the coil will be equal and the impedance of the tank will become resistive and climb to its maximum.
Then, knowing f and C, you can calculate Xc, set Xl = Xc, and calculate L. It'll also help if you replace the 1k resistor with 10k since that'll make the peak much more visible.
You also may be able to see the circuit ring with the rig you have set up if you speed up the horizontal sweep so that you get a better look at the signal across the LC.
If you go here and enter L = 42\$ {\mu H}\$, D = 6mm, l = 6mm, and a wire size of 24AWG, you'll get a nice little coil with a resistance of about 0.26 ohm, and if you simulate your circuit:
with LTspice, you'll get a plot that looks like this:
I've assumed your signal source has a 50 ohm output impedance, and the plot shows a 10 volt square wave offset by 3 volts, DC. The offset is artificial and I added it just to make the plot clearer.
If you'd like to play around with the circuit, here's the LTspice circuit list:
Version 4
SHEET 1 880 680
WIRE -32 96 -96 96
WIRE 64 96 -32 96
WIRE 192 96 144 96
WIRE 288 96 192 96
WIRE 336 96 288 96
WIRE -32 128 -32 96
WIRE 288 128 288 96
WIRE 192 192 192 96
WIRE -32 240 -32 208
WIRE 288 240 288 208
WIRE -32 368 -32 320
WIRE 192 368 192 256
WIRE 192 368 -32 368
WIRE 288 368 288 320
WIRE 288 368 192 368
WIRE -32 416 -32 368
FLAG -32 416 0
FLAG 336 96 Vout
FLAG -96 96 Vin
SYMBOL ind 272 112 R0
SYMATTR InstName L1
SYMATTR Value 42µ
SYMBOL cap 176 192 R0
SYMATTR InstName C1
SYMATTR Value 1n
SYMBOL res 160 80 R90
WINDOW 0 0 56 VBottom 2
WINDOW 3 32 56 VTop 2
SYMATTR InstName R1
SYMATTR Value 1000
SYMBOL voltage -32 224 R0
WINDOW 3 24 96 Invisible 2
WINDOW 123 0 0 Left 2
WINDOW 39 0 0 Left 2
SYMATTR InstName V1
SYMATTR Value PULSE(0 10 1u 100n 100n 25u 50u)
SYMBOL res 272 224 R0
SYMATTR InstName R2
SYMATTR Value .26
SYMBOL res -48 112 R0
SYMATTR InstName R3
SYMATTR Value 50
TEXT -18 392 Left 2 !.tran 100u
