I have a preamp rescued from an old stereo: BA3308
It has a pin "ALC" and the data sheet keeps going on about how splendid this ALC is and how it has a built-in ALC diode and such.
Nowhere does it tell you what ALC is, or how you should use this ALC pin.
I have looked for meanings of ALC online, and I have found 2 possible meanings that would fit this device:
  1. Automatic Level Control
  2. Audio Limiter Control
There may be others...
What is it? How should I connect it? is it an input, or an output? It's a major feature of this chip, and I guess it's assumed you know what it is as you chose the chip.
4 Answers 4
If you look at the datasheet, there is an example application circuit:
Notice how the amplifier is used for amplifying for both recording and playback. The same tape head is also used for both functions.
ALC (automatic level control) was an important function in tape recorders, as the signal had to be the right level, strong enough to overcome noise but not too high to cause saturation. A variable-gain amplifier is a bit tricky to do without distortion, so having it integrated into the preamplifier was a convenience for the system designer.
I don't know what you plan to do with the part, but an obvious choice would be an audio compressor. It won't be super high-fidelity, but maybe good enough for a guitar stomp box.
If they talk all the time about ALC, and fail to explain what it is, all I can say then is that the datasheet stinks.
The application example on page 3 gives us some idea. The ALC signal is taken from the output, via a diode and an external capacitor. That means it's a peak detector, whose level is then used to control the amplifier's amplification. So that looks very much like Automatic Level Control, though Audio Limiter Control is a close relative, if not exactly the same.
  • \$\begingroup\$ this feature is more commonly referred to as "automatic gain control" or AGC in my experience... \$\endgroup\$
    – vicatcu
    Sep 13, 2011 at 16:07
    \$\begingroup\$ For reasons unknown, it is called ALC in tape recorders and AGC in radio receivers. \$\endgroup\$
    – markrages
    Sep 13, 2011 at 16:30
    \$\begingroup\$ It was "Automatic Volume Control" or AVC in radio receivers, at one time. \$\endgroup\$ Sep 13, 2011 at 17:12
As the manufacturer says in this tech note, ALC means Automatic Level Control. There's a block diagram that looks like the ALC picks up the output signal and uses it to adjust integrated potentiometers at the input pins of the forward path.
It looks like the IC is intended to be used with cassette tape recorders. Cheapo recorders often don't have a potentiometer where one can set the recording level. Instead, an circuit tries to adjust the level of the signal that is to be recorded such that it is neither too silent and vanishes in the tape noise, nor too loud so it would cause tape saturation (distortion).
The text next to Fig. 15 explains how to use the feature. Basically, there's an RC combination that allows you to set how fast the IC will react to varying levels of the signal.
See this one: AGC- Automatic Gain Control It mean variable dB on amplifying.
ALC- Automatic Level Control It mean limitation of Peak.
  • \$\begingroup\$ Not really helpful in answering the question. \$\endgroup\$
    – Dave Tweed
    Oct 19, 2012 at 21:58
