I am trying to solve this circuit-
Here is what I have done till now-
- Assumed every diode is forward biased.
- Used mesh analysis to find that in left mesh the current is -1.63 mA, that means my initial assumption was wrong about D3 diode. And it's reversed biased.
- In the right mesh I found 1.74 mA. That means both D1 and D2 are on.
- I again solved this circuit by starting with D3 off and D2 D1 on and found out current in the right circuit is 0.678 mA.
Is my process and results correct? Does the values and diode states correct?
And in PartSim my simulation produced this output which is not matching, but why?
