I have been trying to build an AM radio for a while now and with continued failure, I am trying different avenues.
I understand that Germanium diodes have a forward drop of about 0.3V; to be sure, I put the diode in series with a resistor to measure the diodes forward drop.
What I don't understand is how so many "How to build an AM Radio" articles take the signal directly from the antenna and pass it through the diode. I have used a large monopole antenna (about 20 feet) connected to a tuner circuit (200-1800uH inductor and 10-360 pF cap) and I do not get anywhere near 0.3V.
So, I would like to know, how do diodes work in an AM Radio? There must be something that I am not understanding or doing properly because I have not yet been able to receive and demodulate a signal in my attempts.
  • \$\begingroup\$ I've never personally made a receiver and know very little about radio, so I didn't want to answer the question officially, but the answer may be the antenna. A longer antenna (30ft - 50ft) should give you better results. \$\endgroup\$
    – Tom
    Oct 11 '15 at 22:19
The detector you show is called an Envelope Detector (Wikipedia).
You are missing a couple of important components: A resistor and a capacitor after the diode.
(schematic of envelope Detector - Wikipedia)
When the diode conducts it charges up the capacitor which then discharges relatively slowly through the resistor. The time constant is selected to be long relative to the carrier frequency but short relative to the modulating signal. Envelope detector operation - Wikipedia
The resistor and capacitor fill in the signal between the carrier cycles to get back a close approximation to the original sent signal.
With a more complex signal such as audio you might get something like this:
Extracted modulating signal - Wikipedia
The rapidly changing signal is the carrier while the red outline is the wanted output.
For a simple receiver such as you show you need to be careful that the connection of the antenna and the detector do not disturb the LC resonant circuit so much that it changes the frequency of resonance from where you need it and may also increases the losses to stop it working.
Typically the antenna will be connected to the coil with a small capacitor to reduce such loading and the detector will be taken from a tapping on the coil, not at the end for a similar reason. This will allow the resonant circuit to operate more effectively.
You need what is called a "High Q" in the resonant circuit to help magnify the small signal from the antenna.
Such as in this example:
The diode will actually start conducting at lower than 300mV, probably around 100mV as shown in this chart you get some output evener a few 10's of millivolts of signal.
1n270 characteristic
Even with all this the output signal will be small and you will need sensitive high-impedance headphones - normal low impedance headphones for personal stereos will not work, I have used a crystal earpiece and they work satisfactorily although that was many years ago. You can also feed the signal to an audio amplifier.
There are a number of web sites about crystal radios that can give information to help get yours working - here is one Techlib.com.
  • \$\begingroup\$ My signal is only 5mV. So it is true then that the entire signal is lost if it cannot overcome the 0.3V from the diode? I know they behave differently for AC than DC because I've used a diode (just a diode) to demodulate a signal from a sig gen. \$\endgroup\$
    – Klik
    Oct 11 '15 at 22:43
  • \$\begingroup\$ If you get the resonant circuit working correctly then it can multiply that voltage greatly and allow a signal to be received. One other thing is that the output signal will be small and you will need sensitive headphones - normal low impedance headphones for personal stereos will not work. You can also feed the signal to an audio amplifier. \$\endgroup\$ Oct 11 '15 at 22:47
  • \$\begingroup\$ Kevin, I'm not clear on this. Is the signal lost in the diode if the voltage is under 0.3V? \$\endgroup\$
    – Klik
    Oct 11 '15 at 22:58
    \$\begingroup\$ If the signal is too small it just won't be enough to cause the diode to conduct. However if the resonant circuit has a good high Q the voltage will build up until the diode does conduct so even a small signal can still be received, if the losses in the inductor/antenna etc are too high then sufficient voltage will not build up and you will not get any signal. Also as I mentioned it does not take as much as 0.3v to cause the diode to conduct, \$\endgroup\$ Oct 11 '15 at 23:01
  • \$\begingroup\$ Yes, I meant to write 0.1V. I DID read through your excellent explanation. I will look into your circuit as well, I've never thought of using a notch filter and a transformer like this. To be quite honest, this is my first electronics project so I'm tiptoeing but hopefully I'll be successful. Thanks for sharing your knowledge. \$\endgroup\$
    – Klik
    Oct 11 '15 at 23:05
That's not a very good crystal radio. Try as long a wire as you can find and the strongest AM station in your area. You might be able to get more than the 300 mV it takes to turn on the diode. By the way, nowadays you use a Schottky diode instead of a germanium one. They have about the same forward drop, but are a lot easier to find.
Better crystal radios have two coils that form a transformer. The primary is the smaller coil, which is driven from antenna to ground. The larger coil is the secondary, which is used as you show, except that the antenna is not directly connected to it.
This does two useful things. First, it increases the output voltage. This get past the diode drop more easily, and causes less distortion because the diode drop is a smaller fraction of the output signal. Second, it raises the impedance of the output signal. This is a better match to the type of headphones that a crystal radio is meant to be used with.
I go into more detail on crystal radios here: https://electronics.stackexchange.com/a/150307/4512. Search for "crystal radio" here and you will find a number of posts with more information.
  • \$\begingroup\$ I'm glad you mentioned the transformer because I just took one off an old radio, but it seems to kill my signal. I'll look into this, thanks for the tip and the link. \$\endgroup\$
    – Klik
    Oct 11 '15 at 22:50
  • \$\begingroup\$ You wrote a great answer to that question!! I am doing as you suggested for the double loops (I didn't understand at first). It is working much better for my signal. I've got 10mV now (I'm quite excited). I'm not sure why this is better, but I'm very happy to see. \$\endgroup\$
    – Klik
    Oct 12 '15 at 3:38
