I'm learning how to use an Attiny84. I've generated a fast pwm signal. I managed to understand how to do this:
#include <avr/io.h>
int main(void)
// setup timer0
TCCR0B |= _BV(CS00); // use clk_i/O without prescalers as clock source.
// also enables TIMER0
// set fast PWM mode
TCCR0A |= _BV(WGM01) | _BV(WGM00); // Mode 3
TCCR0A |= _BV(COM0A1) | _BV(COM0A0); // set OC0A on compare match, clear on BOTTOM
OCR0A = 0xff / 2; // 50% PWM
// set PB2 as output. This should enable OC0A
DDRB |= _BV(PB2);
for (;;) {
However, I don't understand why I got only ~30kHz on the scope. I disabled the CKDIV8 fuse and sets my CKSEL to "Calibrated Internal RC Oscillator 8MHz".
I though I could have at least 8MHz PWM frequency. I can't find in the documentation how clk_i/o and clk_cpu are related. Is there any way to gain a higher PWM frequency ?
N.B.: I don't need to have a particular PWM frequency, I'm just testing the chip and trying to understand its boundaries.
